Hi Guys n' Gals;
The dash cover on my 32 GTR has bubbled in the usual place ie the concave right anlged-ish section just above the glovebox. I doubt it can be repaired, does anyone know;
if there's a good dash repairer in Canberra?
how big a job it is to take the dash out of a 32 GTR ie good / bad/ bastard and how long it takes? Searched on the site but found nothing, not looking for a DIY guide unless you happen to have one laying 'round that you prepared earlier, which would be great. The R33 seems firmly in the bastard category from what i gather on the forums and from Adam at BDL but I'm not sure re the 32. I've got the Nissan manual but sometimes the diags etc are so crappy it's hopless.
Regards
https://www.sau.com.au/forums/topic/58887-r32-dash/
If its just the vinyl on top thats bubbled people have fixed it by getting glue and putting it in a very thin tipped syringe. You then poke the syringe through the vinyl (will leave a tiny weeny little hole u cant even see) and squeeze a bit of the glue in then press the vinyl down. This will re-glue it down, seems to have worked for a few people. Might try it myself, got a small bubble developing on the dash
https://www.sau.com.au/forums/topic/58887-r32-dash/#findComment-1126819
Hi Nik;
thought about that too but it's pretty far gone, I think the vinyl has shrunk to the point that it just won't stretch back into place.
Cheers
https://www.sau.com.au/forums/topic/58887-r32-dash/#findComment-1126920
No dramas dude, just take it easy, take your time, and make sure everything goes back where it came from, i didnt put it all back together properly one time and had a few problems which ended up being something very simple and easy to fix
https://www.sau.com.au/forums/topic/58887-r32-dash/#findComment-1133052
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
