hey guys i have got a half cut for sale r34 neo engine rb25det comes with engine loom gear box computer pritty much everything to make it run :P engine is in good condition pics will be up asap earily next week
RB25det neo 5speed manual
wanting 3.5k
0402670354 or [email protected]
if anything else is needed off the front cut dast front windscreen fron gaurds front strusts
post up or email :)
cheers guys
https://www.sau.com.au/forums/topic/58929-fs-r34-neo-engine-package-35k/
Are you going to convert an r33 to r34 ? what about the rear ? wouldn't it be better to sell the 33 and buy 34 , then you will have the real thing .
Thats what i'm in the procces of doing .
Anyway good luck with the conversion .
it is a 5 sp manual :cheers:
no i got a uras conversion kit for a r33 i am selling and i have found a hlaf cut to source out the parts depending on how much this front cut sells for with all the peices will deternian how much the nose conversion will be
you guys have all seen silvias and 180 have s15 nose's now you can upgrade the skyline ones with this kit it is very cheap considering the firs for r33 in australia :)
also would like to say radiator fan shourd everything will go with the engine if any one want front console dash steering wheel front seats i think inculed  plz post up or pm me a offer :(
Hi I have and NEO RB25DE.....will that engine be a straight swap?
  • 1 month later...
yes engine mounts will bolt straight up
Hi do you still have this engine available?
any pictures? i live in sydney, how can i get the engine if i decide to buy?
so the engine is complete? turbo, ECU, wiring loom etc?
Thanks
hey guys it has been some time since i posted in this thread as .... when i first made the thread there was no interest i will have to go cheak out the engine and see what bits have been taken off but it will be a slow process as i am busy and it takes 2 hours to drive down to the factory ... the uras kit may still be avalible
sigh:(
Could you tell me how the mounts and mounting points compare to the rb20det in r32 gtst's?
i have a rb20 in my 260z using stock mounting points - want more to happen when i use my right foot:).
You dont have to bother replying if you dont want to, i wouldn't be able to buy for a few weeks or months due to having to repair the few thousand dollars a theif cost me
  • 1 month later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
