hey guys sorry to bother you
but i have heard that the series 2 turbo is steel wheel ball bearing turbo
is this right?
im up for an upgrade on turbo for my car
series 1 r33 1993
i was looking at a gt30/40 turbo
my engine is stock at the moment but will want to do some internal work
once i start doin shit!!!
as the gt30/40 are around 1700 buck mark
i was seein if there was a cheaper alternative
thats goin to give a power im looking at
im looking at about 260rwkw ?
thanks
https://www.sau.com.au/forums/topic/59062-difference-r33-s1-s2-turbo/
series 2 turbo is ceramic, not steel wheel'd
before you go upgrade your turbo check out prices on/consider
ecu
intercooler
clutch
tyres
exhaust
injectors
boost controller
once i had all of those fitted i would then fit/change turbo
the stock ecu will hold you back and it has boost/fuel cuts, standard timing/fuel maps etc.
aftermarket ecu (power fc, microtech, wold 3d) will have more aggressive maps, settings and are tuneable.
stock intercooler wont do much and you should upgrade to front mount item
stock clutch will get angry over about 180rwkw and slip
you should have some good tyres, 245s or 255s to help traction
replace stock exhaust with 3" turbo back with hiflow cat and front/dump pipe and muffler
replace stock injectors with something bigger, s15injectors are said to be ok (recent thread on this)
boost controller youll need, preferrably electronic (ebc) instead of bleed valve
then after all thats done i'd say new turbo
the current restrictions on the stock gtst are:
ecu
intercooler
boost control
exhaust
get rid of those and add a few more items and youll be ready
of course you can simply ignore our advice and fit a gt30/40 and youll probably get
**** all response, shitloads of lag, angry fuel/boost cut when you it airflow @ 16psi
and lots of heatsoak, wheelspin, clutch burning smell and stressed out engine components
not to mention runing risk or detonation/pinging from injectors and increased inlet temps from stock cooler
also the gt30/40 wont fit to stock manifold so youll need manifold, most likely external wastegate and dump pipe to fit it
hope this helps, someone else may be able to correct/add information to what ive given you
the stock turbo is good for 12psi and probably 210rwkw ?
for probably 260rwkw check out gt28rs or gt28 from garrett, you shouldnt need gt30 for that power mark. sure the turbo may be 1700 but the extra shit you need to make it even run will be 1000 extra, not to mention make it work properly and give good response
I got a SII '98,last of the R33's, it had steel wheels, ball bearing. My car wasn't new, could have been changed, but why change the wheels and not hiflow etc. Ask around, I got a feeling that the last R33's may have been steel.
Why not hiflow, 250rwkw easy, and only $1200 unbolt, give, get back, bolt up. No mods required to dump or mount or oil lines or water lines.
Thanks for the replies
just to let yas know, and forgot to mention, my car is an automatic
it has a 3 1/2 exhaust, gettin a trust intercooler kit very soon
savin for ecu upgrade, apexi avc-r , injectors, fuel pump, fuel pressure regulator
and some internal work
this should also come a bit quicker then expected as im sellin one of my other cars
This car will be a daily driver, and will be mainly used on about 10 psi
on the occasion i will be racin the odd person on the street. (keepin within speed limits) haha
and goin out to test and tune, and would be running then, the max amount of psi for my engine and turbo which will still be safe.
i also know i will be up for a rebuild on the gearbox or another type of box that can handle this type of power ( not really wantin to convert to manual)
Thats why i thought gt30/40
once engine work and the other things i have listed is been done. (knowing puttin this turbo on requires external wastegate and manifold, and dump.
i will be happy with the car and power .
Will let yas know on progress.
I have taken the car out on the dragstrip,
didnt spool it up and had a reaction time of like 1.somethin it did a 16.6
as soon as i get intercooler i will take it out again .
thanks again for replies
the difference is that the intake wheel (compressor) is nylon instead of steel which makes it lighter and (apparently) more responsive.
all r33s have ceramic exhaust wheels.
r34s also have ceramic exhaust wheels and a nylon compressor wheel like the series 2 r33s
I agree with Paul, If you just want to upgrade the turbo and leave everything else dont bother. because your gonna be stuffed. I am running a gt-2540 and yes its hard to get the power to the ground because the wheelspin is crazy. If you want to upgrade the turbo, upgrade everything that goes along with it. Fuel pump, injectors, intercooler.
Also PaulR33 the GT-25 series are built with an internal wastegate so an external one is not necessary and would just be a waste of money.
I had a look into nissan FAST software and noticed that R33's have 6 different part numbers for the turbo which would mean R33's came out with 6 different turbos.
The manual R33's have two different part numbers for the turbo and the auto R33's have 4 different part numbers for the turbo.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
