hey ppl, i jus blew the turbo on my R33 GTS-t this afternoon...
I was wondering if anyone would know the best replacment for this type of car before i go out and blow all my money on a replacement. i dont want one that has no boost till redline either... i want power from down low, so i guess a smaller turbo will be the answer? but which one?
any help appreciated, thanks.
ElBoRo
https://www.sau.com.au/forums/topic/59069-blown-turbo/
hiflow from gcg sydney. will rebuild your core/bearings and allow you to run more boost. wil match stock manifold,dump/front pipe and easy bolt off and bolt back no swap no messing around. should allow you to run 18psi as it has replaced bearings, compressor wheel etc,, speak to gcg in sydney, i think going price is about 1800. you send it your busted turbo, pay 1800 and it comes back "hiflowed".
also it will have same spool up response as your stocker turbo (ie: very good). the series 2 is fast to wind up, usually it can spin 12psi before 2900rpm
https://www.sau.com.au/forums/topic/59069-blown-turbo/#findComment-1128767
the series 2 turbo is a stock gt25 item im pretty sure
yeah brand new is different story to hiflow as you already have the housing etc.
the max stock series 2 efficicency is about 12psi, with hiflow is about 18psi
have seen someone run about 20psi but it didnt make any more power than 19psi but could be due to injecors, ecu etc... lots of many factors
check out the sydneykid config, he uses hiflow, can't beat it for $$$ and response
http://www.skylinesaustralia.com/forums/sh...86&page=4&pp=40
last page, last post. stocker turbo response and lots of power
if you fitted a hks/trust/apexi/samsung/xyz turbo chances are it wont have some low end response and will also require change to oil/water lines/manifold dump pipe etc
https://www.sau.com.au/forums/topic/59069-blown-turbo/#findComment-1128776
my friend sent her MR2 turbo to them the other week and she got it back and it was matched completly wrong to the motor.. like surging when your on boost and accelrating...
i have heard they do really good work on skyline turbo's though, just giving you a heads up thats all.
https://www.sau.com.au/forums/topic/59069-blown-turbo/#findComment-1129103
Sounds like it has been fitted with a leak if its hunting... all hoses pipes etc. snizen?
Would have to be convinced it is a turbo fault, weather too big or not. More like the new levels of performance are making the engine run lean??
Anyhow, ring the guys and if it is their problem they will move mountains to fix it... like most specialist turbo people their work is tops... There may be others round as good - I just haven't dealt with 'em. Call em before you bag em tiger.
TT
https://www.sau.com.au/forums/topic/59069-blown-turbo/#findComment-1129865
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
