Hi all,
Need help and advice.
I changed my 2 front tyres on the GTR today, from 265/40/17 to 245/40/17.
After doing so I noticed that the HICAS light started flashing now and then, didn't think anything of it til on the way home after work it stayed on, also (this may be totally unrelated) I noticed that my battery was sitting at 11.8 volts and dropped to below 8v by the time I limped into my driveway.
As soon as I start the car(after charging the battery) I can hear and feel the hicas doing something, but the volt meter and power FC both indicate that the alternator isn't charging the battery(I've never seen an alternator just die).
Q1. I did notice the battery problem before changing the tyres, could the Hicas problem expedite the draining of the battery?
Q2. Has anybody played with their hicas and if so what can I check(I haven't put into diag mode yet).
How can a car bring so much pleasure, but at the same time cause so much grief!!! Much like a woman I suppose :-)
Any advice would be appreciated.
(a not very happy)Brad
https://www.sau.com.au/forums/topic/59280-help-hicasbattery-problem/
Make sure your power steer fluid is up to level. Other than that, search the forums to find out how to put the car into HICAS diagnostics mode (make sure the steering wheel is straight) and if theres anything wrong it will flash an error code at you, which will help you determine where the problem is.
Also on another note, make sure tyres profiles are the same size on all 4 corners of the car, or else the ATTESA will start to screw up :(
Thanks guys.
I've checked the fluid and it's all good.
It's was getting dark by the time I got home and by the time I got onto the forums to find out how to get into the diag mode I was too tired and way too grumpy to do it.
All the tyre profiles are the same.
But I did disconnect the battery to reset the ecu and it has seemed to have fixed the HICAS prob....maybe..... will check it out tonight...
I've checked all the leads and have come up with nothing, I'll have a look again to day after work in daylight otherwise I maybe searching for a new alternator.
I'll try and post in one of the other forums as well.
Will let you know how I go... why does all this fun stuff happen around holdiays!?!?
mmmmm found this
http://www.skylineowners.com/forum/showthr...5580#post125580
Sounds like my alternator needs a rebuild!! Should be able to get it done before the weekend too!!
All I gotta do is get home today and pull the bloody thing out!
OZR32GTR, just a note on the profiles of your tyres - if the rears are still 265 and the fronts are now 245, you will have different speed readings front and rear.
This will cause torque to be sent to the front to compensate (as it is seen as rear wheel slip) sidewall measurements are a percentage of the overall width - 40% of 265 is 106mm of sidewall, whereas 40% of 245 is 98mm. Not a huge difference, but may be enough to upset your system.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
