when you say back into the bulkhead, where do you mean?
As far as i can tell, this is the only rail damage:
Lower Radiator Support:
Shot from the front:
And one more thing.. these cars are bloody heavy!! Had to push it up the hill into the garage yesterday..
If you want any more pictures let me know..
-Patrick
  • Replies 52
The idea is basically this:
I'll strip the front of the car back, guards, lights, cooler, radiator, air-con, oil cooler etc, then assess the damage, if it looks like it really needs a bench (which i think it does) i will get it done by the pros.
They can do the radiator support and chassis rail and i will bolt the car back together..
-Patrick
It also needs a new set of rear discs.. I think someone did an absolute monster burn out in this thing - extreme brake dust on rear rims, rear discs are ~3mm worn on each side!!
Pic:
I'll get a better picture of this once the wheels are off and the car in the air..
-Patrick
Update:
Today i removed
Headlights
Indicators
Air conditioning condenser
Radiator (bloody hard to get out)
Bottom radiator support definitely needs to be replaced. It is bent in to within 20mm of the engine fan. LH Chassis rail is straight, RH has been bent diagonally in and up by around 25mm. The area where the intercooler piping returns towards the plenum is where most of the damage is, although this pipe does not appear to have been damaged. The battery platform is still in the right place.
Unfortunately it looks like the rear turbo has been spitting out some oil.. not a great deal, but there is some in the piping from this turbo.
I have no pictures at the moment, my mate wanted his digital camera back for christmas.
-Patrick
Did a compression test today after cleaning out all the water from the spark plug holes..
1: 120psi
2: 120psi
3: 105psi
4: 115psi
5: 115psi
6: 105psi
Remember that compression test results are dependent both on the type of compression tester used and the speed of crank, so these results should be taken as an indication only.
Overally I am quite happy with what this suggest: No major internal engine problems with the pistons, rings and valve seating.
A question for you guys, this car is currently running NGK R number 9 spark plugs. Another forum member has suggested NGB BCPR7ES plugs, does anyone know if these will be ok, or do i need a colder heat rating?
Also, when i had power to the car today i checked out the boost controller - the two settings currently programmed are 1.2 bar (~17.5psi) and 1.4 bar (~20.5psi).
Apart from this I cleaned a rear wheel today... It took about 5 hours with ~1600psi of high pressure cleaner and a whole bottle of wheel cleaner. I want to hurt whoever let these wheels get this dirty!!
Any comments welcome,
-Patrick
1: 120psi
2: 120psi
3: 105psi
4: 115psi
5: 115psi
6: 105psi
-Patrick
Hello,
your compression seems too low? isnt 130-150 correct?
Also, you sure the boost controller is Bar ?? Or is it kg/cm2?
1kg/cm2 is 14.2psi.
Petar.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
