  • Replies 416
Posted Images
well here are their specs:
Windows® System 98/ME/2000/XP OS:
* 800 MHz or higher CPU
* 256 MB or more of RAM
* 32 MB 3D graphics card with hardware transform and lighting, such as GeForce 2 or better
* 4 GB or more of available hard drive space
* DirectX® 9.0c or above
* A 56k or higher modem with an Internet connection
im running a 1.4 with a radeon xtsomethingi card thats pretty good and 512 ram, should be fine :D
its a wicked game by all accounts.
im a WC3 junkie  lol... and WoW looks even better... once i get my free broadband in about 3-4months no doubt ill jump on
you can play it with dailup.. i only had dail up for the 1st couple of weeks of playing.. its not that bad
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
