  • Replies 416
Posted Images
i'm a lvl 44 ne rogue on blackrock, with a 15 druid on the same server. also have a lvl 20 tuaren shaman on Kargath.
rogue is very kewl, u might be abit crapped off at the rogue from the mid teens till when u get ur poisons after that your dps skyrockets :)
i went herb/alch on the rogue as it suit you very well the heals and buff potions are a saviour as is 'vanish' once you get it.
yeah i might stop using paladin and go to ne rogue again for blackrock, i wuold get to 12 quicker than what i did originally because i'd know where to go
plus they look the shit!
although paladine armor choise is sweet
well i borrowed my mates copy and installed it last nite. it sez i have around constant 600ms latency, BUT IT DOES NOT LAG ONE BIT! i swear i couldnt belive wot i was seeing!
thanks anyways!
wot server and stuff you guys on? =] maybe ill see yas in there (wen i get it!)
hurry get broadband! you dont want to miss out!
ive got DSL now... but im moving out soon-ish and wont have a PC for a few months.
worthles paying for WoW now just for a month or two then not playing for ages.
i couldnt handle it
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
