  • Replies 416
Posted Images
If anyone in canberra needs WOW let me know i work for a certain store which gives me certain privelages which also lets me buy a game and take it back a year later if i want to or i can just burn it and take it back. so if anyone wants it for free let me know ill hook you up and its applys for any game
are you saying on a very public forum that you are willing to break the law?
yes on dialup
my latency bar is always red. yes iron forge is the worse due to knobs standing in the fires at the suction house.
Prank
set up a dwarf hunter (Kegg) on your server who do i contact in regards of getting hooked up in your guild? He want be my main but will get played regularly.
ooo this is getting intresting, skyzerr33 even though your bar is red all the time its not laggy is it. does anyone go on gorgannash? (dunno if i spelt that correctly) i find that server good, not many people in it either so its a good non laggy place! anyone here a night elve hunter?
i only ever experience lag in areas where to servers can't handle the load.
ie South Shore on Blackrock is almost always a pvp bunfight with raid groups on either side going at it. this causes lag for me and the rest of my guild majority of which are on cable or dsl.
yes D-G even though my bar is always red i don't experience lag. except for in the above mentioned areas and this is due to blizzards hardware on that particular server.
hopefully they sort the 1 off character moves soon and all the servers will be fairly balanced performance wise.
SKYLVIA, its $29.95 for 60 days. and yes i have gotten up to 1600ms - 1800ms and i was still running without much lag. most of the time it will say im on around 600-700ms but it runs like a beauty!!! i reakon it is worth it. Im only a level 10 hunter.... but im getting there =P. besides i dont even have the game, i borrowed and installed my friends version so wen hes not online i go on... im hopfully gonna have the time to buy it one day =]. If people could please leave the servers, and nicks there on and use that would be great!
My mate recently dumped his missus siting the following reason:
"Between my job and Warcraft, I ahve no time to spend with you.."
So she ahd to move out, which is probably a good thing, she is a sour bitch with a major attitude issue, but has a great rack.. I am not into Warcraft, so I probably would have picked a round in the sack with her over the game, but I would ahve to leave very quickly afterwards.
WOOOOOOOOOOOOOOOOOOOOOO finally getting my copy of wow tomorow, about time i get my own copy insted of sharing! anyways, is anyone level lower then 15? if so come train with me and my mate, we can give you a hand.... server is gorgonnash (if i dont lag there neither will you), my name is Clashez =]
Yorik thats heaps funny she mustve been heaps annoying to be ignored for WOW (no offense to WOW im sure its a gr8 game)
I would post a pic of her here if I knew it wasn't going to get me in a heap of trouble.. Like I said I would give her a go over WOW anyday, but I sure as hell couldn't talk to her.. f**kin g hell is he annoying!!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
