we've gotten chromagus to 40% on first try so far. we have a raid scheduled tomorrow so we'll see how we go now.
firemaw is horrible though if you dont get the positioning and tank transitions going.
havent made it to an mc for a few weeks now so im losing out on NS gear badly. still have my gutgore ripper just need a new OH and should be cool :D
  • Replies 416
Posted Images
My guild is in a stage of rebuilding but we managed to get rag down to 40%.
On another note ZG's been nerfed hard! My guild couldn't bring down High Priestess Mar'li before but after the patch it only took 2 shots. And Bloodlord Mandokir use to take atleast 8 goes, but we killed him on the second run. That's with a lot of noobs also.
We've only started MC run but last week the guys got Rag down to about 40% on first run. I'm proud of the guys considering many don't have FR gear. Now if they'd only get off their lazy asses and get some FR gear! lol.
good work :P
we just took down thundarian got our first thunderfury and i must say that is easily a 15man raid instead of what i thought was meant to be 40man. he dropped super quick
since last maint we have taken down up to broodlord (i got the head which is cool :mellow::P bronze flight rep ftw) so now the rest, hopefully we down chromagus tonight
chromaggus down! fkn!
we got our shit together, and seemed to be real simple the time we did it, only 5 deaths as well :rolleyes::) :) !!!
Bloodgfang and mage shoulders dropped, and chromatically tempered sword as well
this is good because earlier in the week we got the untamed blade, and also thunderfury like i said before. :)
we are just going through different strats for nef's room atm, its a bit of a ball breaker, but yeah, chromaggus was pie
chromaggus down again and nef to phase2! so awesome.
i also scored my first bit of bloodfang, being the shoulders, because they dropped again :O need 2 more for the 3piece bonus and only one damn nightslayer for the 5piece bonus.
edit: before i forget, we now have gotten rag down to 19% before sons, no pots etc, just pure smashing, bout 2 deaths because they missed the knockback call and landed in lava. perd blade dropped for the second time and again went for over 100dkp
Well, I'm officially retiring from WOW. RL and WOW clashed and it's time to rebuild my life. I wish I could tell you guys what happened but it wouldn't be fair on the other parties involved.
Overall it's a fun game but it's just so time consuming. I can understand the addiction but now I realised how much I've missed out on back in the real world.
Woooooo Rag 32% before spawns, hope we can do it again this week haha.
It is time consuming, but you can dodge around it to play and do work/rl things to. Best thing if you wanna do that is take a break for a month, get back to WoW and keep certain days for shit you really need/want to do IRL. Good luck
NEF DOWN!!!@@!@!@!@!!@@!!@!@FKN!@!@!1!
if anyone wants to see our guilds site its:
Eternal Requiem
bwl is down to a 2 night clear pretty much, we'll see how we go tonight, we have chromaggus and nef left. chrom is just cake atm no matter what breaths
60 lock on Blackrock with AlterElectus, will be running Blackwing Lair tonight, Guild is up to 2nd boss in there, and can finish MC in 3.5 hours. Now anyone else on blackrock think that the sever should just kick over and die, instead of these queues and lag issues.
the sooner blackrock gets migrated to the new (hopefully faster and more stable hardware the better) only problem is they started with the east coast servers. blackrock is westcoast :P
amazing what happens when we finally get enough ppl online. razor to firemaw done all first attempt. not bad seeing we had 10 ppl with no epics and it was our first shot at firemaw. still we are behind where we should be.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
