I am trying to find out wats wrong with my transmission. its an rb20 enging, box, and a brass button clutch
the problem just started last week and it getting worse and worse.
you cant actually feel the problem but you can sure as hell hear it.
you can only hear it when the clutch is out.
mostly when driving but even sometimes in neutral at idle, it sounds almost the same as the noise from a whining diff but lower pitched and it seems to sort of phase in and out like a whoosh whoosh whoosh and it is relative to how fast i am going.
is it my gearbox or clutch? and is it likely to die suddenly or have i got a couple of weeks to fix it?
any help appreciated
https://www.sau.com.au/forums/topic/59905-gearbox-or-clutch/
Guest two.06l
probably only a thrust bearing noise. Twenty bucks for a new one but $200 to get it fitted.
Mate, i'll tell you what, same deal happened to me. this is how you determine which is what. If its the thrust, with your clutch only half engaged it'll go away.. if its the gearbox do this, turn all ur music etc etc off... then drive the car, place it in first take off and go to about 40kmph and roll.. push your clutch in, and if the noise is still there its the box, if its gone... its the clutch.
to easy!
if you can DIY it only costs a few bux (maybe 100-200$) to rebuild the box and replace all the bearings etc, takes a weekend to do it, all the right tools.. and a mate to help you aswell!!!
Hope all goes well!
Dayne
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
