Guest two.06l
I know how to do it but the bastard won't come out. I've hit the crap out of it (even with a mallet) and it won't budge. WD40 doesn't help either :)
any ideas?
you obviously have the nut off ??? (please say you do)just persist with side to side tapping with rubber mallet working your way around the rim of the wheel.
CerealK, try it at 10 o'clock 2 o'clock and 6 o'clock hitting perpendicular to the shaft axis.
Heel of your hand should be enough. Don't worry about fore and aft direction hits.
If all that fails park somewhere like a beach/shopping centre carpark, grab the wheel and shake the bejeesus out of it while making a noise like like a dying moose. You may get on telly. :)
Never know the wheel may pop off too.
"if in doubt, give it a clout".....just make sure that nut is still done up with plenty of thread.
the one on the GTR was damn tight to get off.
Agree with Drunken. The bigger the doubt, the bigger the clout. Try hitting it with the palm of your hands but not from the back, head on as if your trying to fit it back on. You need to do it rather quick to get some vibration happening to break the seal between the two metal surfaces.
By the way, hope u know if its a pre - '95 (pre series 1.5) Skyline, its actually illegal to remove the factory AIRBAG wheel ! so keep wishin !
If you looked a little more closely you would see that SK owns an R32 GTS-t....
I just recently removed the stock wheel on my R32 GT-R. It was fscking bitch to get off. In the end it took me yanking the top as hard as I could while my dad whacked the bottom with a rubber mallet.
Oh, and make sure you have the nut on a couple of turns so it doesn't fly in to your face :D
LW.
no no no you are doing it all wrong.... you have to hit it at exactly 2:43 and 9:57 (none of this 10 and 2 crap) it's the only way.
Or just drop down to UAS and borrow 2.5mins of their time...
Surely CerealKiller would have his steering wheel off by now, and the new one on??
I bought a steering wheel puller from autobarn and it came off shortly after that. It was still a hell of a fight to take it off even with the kit (I thought I snapped the centre bolt when the wheel popped off).
New wheel's on and it's good but the horn button is slightly different to the one I had. So no horn at the moment. I'm gonna see how much it is to get the old one re-trimmed, anyone had experience with this?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
