Ok! Went for a drive last nite, everything huckydory. No probs. Missed 3rd, kinda hit the selector wall thingy, big loud crunch noise. Then put it in 5th, kept driving, all gears work.
Then come this morning, go for a drive, no problems. Go to get on the highway, go to put it in to 5th, wont go in, (wont go in being it will go in its little slot all the way, but wont actually engage the gear properly) it then crunches as if the gears are JUST touching, going by the noise and the feel thru the gear stick. But all other gears are fine, no different.
The engine is an RB20DET, and the RB20 box. Car is a cefiro but I dont see how that would matter.
Any help would be REALLLLLY nice, cause I have NO idea, other than maybe not enough gearbox oil, or maybe the selector.
https://www.sau.com.au/forums/topic/60217-strange-gearbox-prob-5th-gear/
It sounds like a selector problem to me . You will find that the selector runs out of travel , it wont go down enough to select 5th or the fork inside the box has let go , there is a roll pin holding it in place .
Try putoing it in 5th while stopped with the engine off then strt it up and slowly let the cluth out to see if it engages , if yes then its the selector .
Try puting it in 5th while stopped with the engine off then strt it up and slowly let the cluth out to see if it engages , if yes then its the selector .
It depends on what it is , at the very least you will have to remove the gearstick and see if the selector operates , it should as it engages the other gears .
The box may have to come down if the fork roll pin is off or the fork has jumped the 5th gear hub ( possible ) but hard to say without seen it .
If thats right he should still be able to engage 5th but crunch as it goes in and egage normal when the car is stopped .
I reckon it sounds like your 5th syncro is now in a pile at the bottom of your gearbox...
This might help you make up your mind
http://auto.howstuffworks.com/transmission.htm
Sounds like you missed 3rd and grabbed 5th instead.....but hard.
I'd say most likely a broken 5th selector fork. One 'arm' is probably broken off, which would allow only near or partial engagement. Seen it before with RB30 gearboxes (v similar design), they have an alloy selector fork, which can break under hard/harsh shifting.
Yep, Id agree with that after talking to a few very helpful but rather booked up gearbox shops today. That or the gear has posibly come loose.
It's also possible the mainshaft nut has come loose, but usually when that happens the first signs are that the gearbox starts jumping out of 5th gear and gets progressively worse. Since your problem started happening rather suddenly it's more likely somethings broken.
I'd also recommend looking closely at the condition of the bearings....particularly the countershaft bearing in the steel sandwich plate. It's not uncommon for this bearing to fail in gearboxes used hard. I've actually got an R32 GTSt gearbox apart at the moment that seemed in OK condition, but disassembly has revealed the CS bearing cage has disintegrated and the balls literally fell out. I've seen this before and others have reported similar problems. In fact I'd recommend replacing these bearings while its apart (the CS bearing is only $10...retail), but the labour cost might be high since to get at it requires complete dis-assembly.
Quick up date. It is the selector fork. Whats happened is its partly broken/bent, hence it would go in to gear the night before, and not in the morning, posibly due to heat in the gearbox, etc making it easier or harder to go in to gear. So thats a big NO to gearbox fairys.
Anyway, while the gearbox is out its going to get a reco, all bearings and seals done, as its saving me $300 by doing it now instead of later.
Now a big plug for the gearbox shop! Im in QLD, and I went to Springwood Gearbox repairs. The guys were unbeliveably helpful, friendly, happy answer my stupid questions (I actually mentioned gearbox fairys to them) fair priced, and actually are doing what I asked, fully recomend them. (atm anyway, I havent got my car back yet, but they said tomorow no worries)
Just the update.
It was the selector fork, it had partly broken/bent, hence I could get it in to 5th the night before, and not the next day, probably heat being the factor there. (no gearbox fairys)
Im going to get all the seals and bearings replaced also (with stronger items) as its $300 cheaper to do it while the box is out and half apart than do it in 6months time.
Also a big thanks to the gearbox shop (free plug!!!) Springwood Gearbox Repairs in Brisbane. The guys were really helpful, quick to get back to me, had all the info and prices ready before they called, basically did what I asked, and more. And answered my stupid questions without treating me like a tool. They also seemed well priced.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
