but that's the thing... i NEED THE SMALLER ROTORS :D
The rotors you have can be easily machined down to the correct diameter. I know someone that could do it cheaply, but he's in Sydney on holidays at the moment. Heck, I'd do it myself but I'm not back at work for a couple of weeks.
Either way you need R33 calipers or smaller R32 rotors:(
Since the calipers go for the same money id sell the calipers and use the larger R33 rotors that you have already drilled/modified to 4 bolt with the suitable R33 caliper...check the for sale thread, plebty of wrecked R33 to strip bits off. Post the R32 cqalipers on Silvia or Performance forums and see how you go.:)
Going price for rb20 calipers is around $250 a pair. R33 maybe $50-100 more.
I'd be wary of machining down a disc made for one diameter to another - due to the lattice construction - its not simply just one solid chunk of metal. Wouldn't want them shattering at 150km/hr braking. But it may be possible I guess.
Gordo, don't sweat it mate, it's just a lump of cast iron with some vanes holding it together. Used to have to resize the rotors on the 1600 rally car all the time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
