  • Replies 300
Posted Images
Well guys, I have just removed the Pepsi can gasket from underneath my BOV. While it was blocked off I noticed that boost came on much harder and also faster in between gear changes. I tested this on stock boost with the factory solenoid controlled by the ECU and also with the solenoid grounded running straight 7psi. On both settings there were absolutely no idle/stalling issues. I only drove about 10KM as I do not want to find out how reliable this setup is.
It sounded fulleh sik but also made the car more responsive on boost and also quicker to get there.
Is there anyone else who has run their factory RB25 S2 turbo without a BOV for a lengthy period of time who can report on reliability?
Haha I used Coke :(
Yeah the turbo will be fine, even at 10psi or higher without a BOV there would be no damage. I think people start thinking stuff in there head and panic, when theres nothing to worry about.
Are you gonna keep the fully sick setup?
Yeah i have the stall problem sometimes, do you know what it is caused from?
Ive done about 1000km
Edited by r32matt
Aside from making you a hectic bro - I have found that it has made my car more responsive, keep in mind that it is a genuine low kays S2 33 gts and i am running stock boost with a blitz pod and 3" cat back otherwise standard.
lol!
Im guessing you havent read the last 14 pages :(
Putting some metal or a coke can under the BOV blocks it off from the intercooler pipe. Then you just block off the tube that runs from the manifold to the BOV and you will get Fully Sick Flutter.
If you want details or instructions just PM me :(
Edited by r32matt
Ah if u can fit it in the gap, it won't do a whole lot, the can wil probably get shaken up and will eventually de-carbonate, it won't cool it down either, your best bet is the fridge
haha i didnt understand any of that?? :(:woot::(
haha!! Nice
Nah he doesnt mean a full can :(
Gotta cut the can out to be the shape of the BOV. Put it in like its a seal and it will block up the hole.
The small tube which runs to the top of the BOV - Unplug that from the BOV and block it up (screw or something)
Would you like a diagram? :(
Just curious y did u block the tube off?
Just that i didn't think it would matter, it's only for pressure regulation (i think ) and as it's not getting any pressure i'd think it wouldnt make any difference whether blocked off or not. Correct me if im wrong but air only goes into the manifold nothing goes the other way right? (which i probably am not)
And na u shouldnt need to block the plumbback as it's not getting any air to it either
Edited by 123456
Nah the Plumb Back is fine, ive left all of that still on.
When I left the manifold tube unblocked my car wouldnt boost properly and was holding back, felt really bad!
Im pretty sure the tube is a vacuum which opens the BOV when you take your foot off.
What have u done with your manifold tube? did you leave yours in the BOV? I guess that would work the same if the BOV wasnt opening. Hmm might have to try, but yeah had a few boost problems with that pipe.
Edited by r32matt
Yeh i just left mine on BOV,
Only reason im asking is coz im lazy and if i decide im sick of flutterz i want it to be easy to switch back
"Im pretty sure the tube is a vacuum which opens the BOV when you take your foot off"
Yeh thats what i meant, wasn't thinking of what i was typing lol
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
