  • Replies 300
Posted Images
Well guys, I have just removed the Pepsi can gasket from underneath my BOV. While it was blocked off I noticed that boost came on much harder and also faster in between gear changes. I tested this on stock boost with the factory solenoid controlled by the ECU and also with the solenoid grounded running straight 7psi. On both settings there were absolutely no idle/stalling issues. I only drove about 10KM as I do not want to find out how reliable this setup is.
It sounded fulleh sik but also made the car more responsive on boost and also quicker to get there.
Is there anyone else who has run their factory RB25 S2 turbo without a BOV for a lengthy period of time who can report on reliability?
Haha I used Coke :(
Yeah the turbo will be fine, even at 10psi or higher without a BOV there would be no damage. I think people start thinking stuff in there head and panic, when theres nothing to worry about.
Are you gonna keep the fully sick setup?
Yeah i have the stall problem sometimes, do you know what it is caused from?
Ive done about 1000km
Edited by r32matt
Aside from making you a hectic bro - I have found that it has made my car more responsive, keep in mind that it is a genuine low kays S2 33 gts and i am running stock boost with a blitz pod and 3" cat back otherwise standard.
lol!
Im guessing you havent read the last 14 pages :(
Putting some metal or a coke can under the BOV blocks it off from the intercooler pipe. Then you just block off the tube that runs from the manifold to the BOV and you will get Fully Sick Flutter.
If you want details or instructions just PM me :(
Edited by r32matt
Ah if u can fit it in the gap, it won't do a whole lot, the can wil probably get shaken up and will eventually de-carbonate, it won't cool it down either, your best bet is the fridge
haha i didnt understand any of that?? :(:woot::(
haha!! Nice
Nah he doesnt mean a full can :(
Gotta cut the can out to be the shape of the BOV. Put it in like its a seal and it will block up the hole.
The small tube which runs to the top of the BOV - Unplug that from the BOV and block it up (screw or something)
Would you like a diagram? :(
Just curious y did u block the tube off?
Just that i didn't think it would matter, it's only for pressure regulation (i think ) and as it's not getting any pressure i'd think it wouldnt make any difference whether blocked off or not. Correct me if im wrong but air only goes into the manifold nothing goes the other way right? (which i probably am not)
And na u shouldnt need to block the plumbback as it's not getting any air to it either
Edited by 123456
Nah the Plumb Back is fine, ive left all of that still on.
When I left the manifold tube unblocked my car wouldnt boost properly and was holding back, felt really bad!
Im pretty sure the tube is a vacuum which opens the BOV when you take your foot off.
What have u done with your manifold tube? did you leave yours in the BOV? I guess that would work the same if the BOV wasnt opening. Hmm might have to try, but yeah had a few boost problems with that pipe.
Edited by r32matt
Yeh i just left mine on BOV,
Only reason im asking is coz im lazy and if i decide im sick of flutterz i want it to be easy to switch back
"Im pretty sure the tube is a vacuum which opens the BOV when you take your foot off"
Yeh thats what i meant, wasn't thinking of what i was typing lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
