r32 GTS Type S (brisbane)
5sp Manual
140k's
electronic sunroof
electronic front spoiler
power everything
kyb coilovers all round
genuine nismo shadow chrome mags
blitz panel filter (changed from pod as gives better performance)
custom silver interior paint
electronic climate control
gtr wing
rhino 2 point immobilisor with keyless (not installed)
kenwood 6 inch competition splits
pioneer mp3 cd player
recently received major service 5000klms ago:
new timing belt
new water pump
new water lines
new radiator
new idler bearing
replaced gear oil, diff oil and flushed engine oil
brakes shaved and cleaned
reg untill june
recorded a 15.1 @ 92 mph at willowbank 1000klms after major service
$12500 o.n.o :flamed:
or will consider swap for gtst plus my cash adjustment
https://www.sau.com.au/forums/topic/60907-r32-gts-type-s/
  • 3 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
