No I haven't bought mine yet, however if I lived in the UK and had an exceptional amount of money, the new EVOVIII MR FQ400 would be top of my list.
0-100 in 3.5
Article Here-> http://driving.timesonline.co.uk/article/0...1406902,00.html
Some quotes
"The brakes, which are to a bespoke specification, are so powerful I half expected them to trigger the airbags"
"I have it direct from Mitsubishi that 400 refers roughly to its power output and FQ to the words that come out your mouth the first time you sample it. And, yes, the Q is “quick”."
10 points to whoever works out the F in FQ first :)
It's also in the latest SPEED magazine I beleive.
https://www.sau.com.au/forums/topic/60923-the-evo-has-landed/
There is a bloke at work who wouldnt shut up about it. He s totally in love with it. He reckons he read an article which said that they took it for a spin on the track and it won against the Zonda. With that horrible torque curve i doubt it is worth anything on the track. Unless its got antilag its only good for drags.
Depends on your ability to keep revs up IMHO. Evo's have a relativley close ratio box, so a bit of the ol' heel/toe and even shifting into 1st if neccessary (OMG! People do that! People like me :P ) and you could probably do alright.
On the subject of being in love with it. I have already have two wet dreams about it. The best one involved strapping into some gravel and hitting the gravel mode button. The sheets will never be the same again.....
:bananaman:
Depends on your ability to keep revs up IMHO...
Against a Zonda on tarmac? No way. It just wouldnt have the response needed to corner.
Read this:
http://www.lancerregister.com/showthread.p...15&pagenumber=6
Quite interesting seeing all the Evo boys creaming over the 400.
If you keep the revs up in it, its a very quick car point to point. I have seen video of it whooping a Lamborghini Murciellago around a track, and before anyone crys foul about inexperianced drivers, the Lamborghini was being driven by a professional European touring car driver.
It is a very very very quick car point to point through corners, you just need the brains and balls to know how to drive it properly :D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
