hi, i own an R32 gtr 92 model, its got stock internals, stock gear box, bout to have 2 Garret 350hp roller bearing turbos, APEXi power fc and a few other minor mods. just wanting some feed back on the clutches. what are the stock 1s like? Approx what power can they handle? If i put a twin plate or even heavy duty clutch in will the gear box hold up to the extra pressure? And does any1 know of any other genuine Tommy Kiara gtr's in aus?
https://www.sau.com.au/forums/topic/61006-gtr-clutches/
Hey mate, i have a 33 GTR which is kinda of relative, its seen its fair share of drag meets with a Daiken Twin Plate Rated at 750hp and the gearbox is holding up fine, im currently making about 340hp at all 4, i fried my stock one after a week and the car was still relatively stock, i also have about 4 friends with GTR's that all cooked stock clutches with relatively stock cars in less than a few months.
https://www.sau.com.au/forums/topic/61006-gtr-clutches/#findComment-1154303
Hi tommy boy is that the green one from street machine or another one?
Anyhow a standard clutch won't hold long at all especially with those mods. I put in a NISMO twin plate (sprung centre) and its fantastic.
Mine came with the badge and a couple of Tommy things but I wasn't even aware they did a R32?
https://www.sau.com.au/forums/topic/61006-gtr-clutches/#findComment-1154331
yeah morgs it is the green 1 from street machines, i bought it private of the guy who bought it from them though. and yeah its genuine tommy as far as i know, a mate (who know a fair bit about them) told me that they made about 250 tommy r32's. most of them went to the tracks in japan though, and as far as i know there is only about 15 tommy 32's in aus. Does any 1 know of what was done to them exactly? ive been told , mine may a 2.8l hks bottom end it, dunno if its true though i only know of the cosmetic stuff.
https://www.sau.com.au/forums/topic/61006-gtr-clutches/#findComment-1156045
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
