I guess if what you said wasn't slanderous, there shouldn't be any problems as people are entitled to their opinions and thats what makes us all individuals.
As long as you're making it completely clear that you're only doing this to appease someone else, which means that its a false apology, it's all good :cheers:
https://www.sau.com.au/forums/topic/61117-apologies/#findComment-1155847
my apologies for some of my behaviour on here recently. i have damaged the trust put in me by some.
i hope this is one of the first steps on the path to regaining it and showing sincerely that im sorry.
tj
wow.. you're like the coolest virgin i know..
good on ya mate :cheers:
https://www.sau.com.au/forums/topic/61117-apologies/#findComment-1155873
Well,
I think it's terrible that Tom here can't have his own opinion on something/someone that has had a great deal to do with Skylines, SAU and SAUWA.
Anyway, I've put waaay more than my two cents in a thread that I know nothing about.
Jason.
https://www.sau.com.au/forums/topic/61117-apologies/#findComment-1155876
I totally agree with u there uneekwahn. I missed all the hubub and didnt get in before it was deleted but i think i still got the jist of it.
Unfortunately this is a public forum and the right to free speach does not apply. We cant have everyone coming on to badmouth the guy down the street about the fact that he sold him a bag of oranges with 2 apples in it now can we. Most of the time you can say what you want to say or insinuate something that u are not allowed to say but all out sledging matches just screw everything for everyone.
I agree with the "no one cares" thing. People you meet in person generally behave nothing like what they do online, completely different world. Ive never held anything against anyone ive met from the forums and then know in reality and i hope i never will.
Well unless they badmouth my fluffy dice that is.
https://www.sau.com.au/forums/topic/61117-apologies/#findComment-1156329
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
