what skylines in australia have the most power at the wheels?both gtr & gtst?
Are you talking outright figures?Or road rego'd,dyno-queen,drag car(which would prolly be the outright record,I'm guessing...)?I think RB30-POWER would be right in saying Mario's R33,GTR-700,would be it,but then again,I've never seen an official dyno sheet...drag racers are really coy about letting figures be known!Most are happy to talk up their "easy 800kw" cars,but LeeWah's is about the biggest hitter(GTR) in Oz,that I can think of,that has a printout to prove it.
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1156915
In Oz, there is without a doubt the Mario's GTR700 is the most powerful.
I guess you could split this into 2 different categories, race and street regoed cars.
In the race category I'd put the following (as judged by ETs and trap speeds):
GTR700 R33 GTR
Kier Wilson R32 GTR
Munro R33 GTR
In the street category, I'd include the following:
Theo's R32 GTR
LeeWah R33 GTR
RacePace R33 GTR
Ice Performance R32 GTR *
IWIN R33 GTR *
* - Has not recorded a time on the drag strip but publically run dyno runs have been recorded.
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1156956
Nowhere did I mention I had more power than IWIN. IWIN was mentioned on the list of most powerful cars.
I was only judging a cars power by drag strip times as dynos read differently depending on calibration so the only way of getting a half accurate reading is at a drag strip. IWIN (as far as I know) has not made a pass down the strip so it was hard to tell where it would fit in the World of Powerful GTRs.
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1157143
A while ago,the guys from Sub Zero in QLD had a head kicking GTS-T...can't remember power figures exactly,but it was a tough unit...I'll zip through my Zoom mag's to see if I can dredge it up,even if it's only a reference point...
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1158821
That would have been TRY-09 which ran some very tidy numbers in QLD. There was an article for it in HPI awhile back too.
Oh and OBEHAVE and BIGPSI (I believe which is a GTS-T) are another couple powerful GTS-Ts running around and pulled nice numbers on the strip. There is also another red 3L GTS-T running around Melb owned by a certain FunBoy looking Fang Artist.
I was only quoting GTRs as I don't follow the GTS-T scene as much. If someone else wants to list the most powerful GTS-Ts going around, feel free :(
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1158920
thanks for the input. I have an r32gtst that makes 779.7rwhp hopefully in the next couple of months ill run it down the strip.  thats why i asked for gtst as well.
Frig, that is a big number. Obviously not a RB20.
Any specs you want to share, RB26DET or RB30DET?
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1160532
HOLY CRAP! I take it there's a dyno sheet to back you up? That can't be a RB20.. Whadda ya got? Or are you waiting to spring a suprise on someone?
https://www.sau.com.au/forums/topic/61157-bigest-power/#findComment-1161174
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
