  • Replies 1k
Posted Images
Wahey!
just tested my controller and its working.
Now need to fit it in the car, but as allways here in the uk its friggin raining!
Hetz
Of course it's raining - it's your summer time! Wait a second, it rains in winter too!
Just joking, though I always found it strange (when I lived in London) that people were complaining about how hot it was when it (rarely) got into the high 20's! :-)
Ian
Hi guys,
just had a quck query i just finished building my kit, but have one resistor left over.
Its a white block type one it says on the resistor 10w-10RJ
Does anyone know what its for?
cheers
hetz
Load sharing for the solenoid, the Nissan solenoids don't need it.:D
load sharing ..whats that
Some solenoids (NOT the standard Nissan ones) don't like being held open for long periods of time and they get hot. So you use the 10 ohm 10 watt resistor in series with the solenoid to "share" the load. That way the solenoid draws less current and doesn't get too hot.:D
PS; for more details refer to page 142 of the book "Performance Electronics for Cars".
ahh k so u use the resitor to drop the voltage across the solenoid ....but then doesnt the ibc switch more than the 3 amps its rated for ?
Ooops, that'll teach me to write things form memory, should be "series". Previous post amended:cheers:
Load sharing for the solenoid, the Nissan solenoids don't need it.:rofl:
Ah righty!
i might need to use one on mine then, i dont have a nissan, i have a rover. Still havent got round to fitting it in the car yet. Im hoping it will work well, as the rover doesnt use a AFM, it just relies on a map sensor.
Hetz
right,
I got my controller fitted in the car but am having problems reading a injector duty cycle :huh:
With just the power to the unit, led 1 and led 2 are lite up on the board? i thought only led 1 was supposed to light up?
Ive tapped the injector wire and i dont get any reading at all on the controller? also the led just stayes lite up?
any clues as to whats going on?
cheers for you help
Hetz
right,
I got my controller fitted in the car but am having problems reading a injector duty cycle :)
cheers for you help
Hetz
Make sure you are using the correct wire on the ECU pin outs, it is soooo easy to use the wrong one.:huh:
I am having problems with my Jaycar ebc. Car is r33 gtst
The unit is working fine. I.e. it reads the injector duty fine, the display works fine etc, I can change the solenoid duty cycle and I hear it clicking quicker or slower.
I believe there is a problem with my plumbing. With the solenoid fully open, I have no boost control. In 1 second, from 5psi, it went to 15 psi. I will be more careful in the future not to over boost again.
I am running a vent size of 1.2 mm.
I believe that I have the vent plumbed into the wrong place. I plumbed it where the stock solenoid bled to. However, I am also unsure if it was plumbed to the right place, as the hose had been changed to a blue hose by the previous owner.
Reason I believe it might not be venting to the right place? with the vent blocked off, i.e. plenum > solenoid > waste gate, it works fine. changing the solenoid duty changes the boost build and max psi it reaches.
however, with the vent connected, it has no boost control. Therefore I have come to the conclusion that the vent is reliving the pressure that should be used to open the waste gate.
I have it plumbed as follows:
intake > bottom nipple of solenoid
top nipple of solenoid > t piece
t piece nipple 1 > waste gate
t piece nipple 2 (1.2 mm hole) > bov return pipe.
Questions:
1. which of the solenoid nipples is the in? it's the bottom one right?
2. what is the problem with my hose plumbing? Is the vent in the right place? Is it meant to be connected to the bov return pipe?
So why don't I have boost control? the difference is simply vent = not working, no vent = working fine. Therefore I assume it has something to do with either the vent size or where it is connected. a 1.2 mm vent is already very small.
Cheers
Questions:
Cheers
As per this previously posted picture (on page 2 of this thread)
As you can see the boost feed (from the intercooler pipework) goes into the top fitting on the solenoid.
The bottom fitting on the solenoid goes to the T piece. The RHS of the T piece goes to the wastegate actuator. The hose coming of the LHS of the T piece has the vent in it, that hose goes to the inlet pipe of the turbo (in combination with the standard BOV return).
As a clarification, back on page 16 of this thread I posted this diagram;
As you can see from the above diagram (page 136 of the Performance Electronics for Cars) the size of the "vent" determines how much airflow goes to the wastegate actuator. If the vent is too big, not enough air flows to it and the diaphram doesn't move (open the wastegate) and you get no boost control (it just keeps going up).
The first thing I would do is run the vent to atmosphere, as it is in the above diagram. Then see if the IEBC controls boost OK Don't forget to block off the hose.
Hope that is some help
has anyone tried this fuel adjuster kit, like a vine pressure controller?
eg get a gm2bar map sensor or similar and rem map for map sensing replacing the afm altogether? gm's run 0-5v like most map sensors,
a map semsor must have a similar voltage curve to a afm?
low volts under vacume or low loads, higher volts under high loads or boost? this also would work fine in closed loop mode? any input from anyone thats tried it? may be a much better alternatve for me, im running twin turbos with a rb20 ecu and dont want afms, or to change to a rb26 ecu and run more wires for the rear afm,
AFM's are the best load source by far, MAP sensors are not even close. Because you can have the same pressure at different loads, only an AFM can tell you the CORRECT load. My advice (as always) is to use the best load sensor, and that's an AFM.
As for the problem of running wires for the extra AFM, you don't have to. Simply parrallel up the outputs of the 2 X AFM's and feed that via the standard wiring harness. The ECU sees the movements in the voltages of the 2 X AFM's as a single change, so you tune as you would if it had only one AFM.
:) cheers ;)
I am up to the stage of calibrating the DFA. I am not able to change the volage with the test pot, I tried to wire it up like FIG.6 in book, but I am not sure if its right? I've got it connected to the car battery and it reads 12.5V, try to get it to 12V with test pot but does not change V at all? As pic shows how I had it set up, is it wrong? any sugestions? Thanks
The DFA has to be actually "on" to get any output, so if you set the DFA to turn on at 14 volts (car running condition) you need to apply 14V to get any output.
I had it set to under 12V so it was on with red LED on too.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
