  • Replies 1k
Posted Images
My guess, in the "after tuning" A/F ratios the lean running at high rpm is nothing to do with the DFA. The sudden upwards flick is generally a sign of a failing fuel pump, fuel pressure regulator on the way out, blocked fuel filter or dirty injectors. I would have those potential issues eliminated before trying any further tuning.
The lumpy power graph is a dead give away for the standard ECU rich and retard mapping. So is the random black smoke (rich). R&R is triggered by AFM readings outside what the ECU expects, so any unexpected deviation from normal causes the ECU to adopt R&R mapping.
The 0.2 volts difference between input and output voltage is unacceptable, that is more than many of the correction factors you will input. It really needs to be trimmed out. If it is consistent (eg; always 0.2 volts higher at all input voltages) then it doesn't matter if you are tuning on the dyno, because the mapping will compensate for the input/output difference. It certainly matters if it is not consistent (eg; 4.6 volts in doesn't always = 4.8 volts out) or if you want to compare settings with others. Yours will always be several load points different to compensate for the 0.2 volts error.
If it is a consistent 0.2 volts out at all input voltages, my first check would be the resistor values. An incorrectly placed resistor will most certainly cause that sort of issue.
:) cheers ;)
All the resistor values should be correct I double checked with a multimeter all there values.
I did find with the calibration that when I had the multimeter on the input side as soon as I took the multimeter off it the load point would change by about 3 points. i.e. would go from 100 to 103 or something similar. I thought the multimeter was zapping some of the voltage as I was only using the silly trimpot that would fluctuate quite a bit
For the boost restricting thingie majig :(
is this basically what u need to do even tho i realise the 'tubing' is different lengths? (swaping the inner 'restricter')
also do Stagea's have a solenoid? (RB25DET from R34)
Edited by illusiVe
Yes, zakkery the same as R33GTST
:) cheers :D
another noob question.
IF i installed the EBC without any changes... are all settings programed to 0? if so that would mean the wastegate = COMPLETELY CLOSED (i think) = u dont want to hit boost.
so do i need to enter any settings before i kill my turbo being the noob i am :(
Takes about 1 minute to change them all to 0. Then low boost, if any boost at all.
:) cheers :D
so when i install the IEBC that it will take the current settings i have, then i can adjust the curve from that, defult on the IEBC is NOT 'locking' the wastegate closed (god im stupid).. and i am soo buying that book... that'll learn me
Thanks SydneyKid, I was thinking there was a problem with one of those things too
I'm doing the fuel filter this weekend and cleaning out the injectors.
For testing the injectors is looking at injector duty cycle % enough to determine if it is faulty/clogged or not?
Nope, injector duty is what the ECU is telling the injector, not what the injector is actually doing. Unfortunately it is an injector out, clean and flow test job.
:P cheers :D
Hey All,
I went to the dyno yesterday and got my DFA tuned. It took an hour and a half. This is what we did,
-Adjusted the fuel trim.
Some one will have to explan this to me but he added in more fuel down low. I've seen this on SAFC graphs and I dont get why you increase the voltage at cruise levels.
Power run - low boost.
Suprisingly, my fuel ratios were 12.5\1 with out any adjustments. I put this dwn to a slight BIAS of about -0.03 volts at the top end.
-tuned the IEBC to about 11 PSI.
-High boost run
Now for the bad news.
He found that at high revs the ECU was pulling out a heap of timing - and getting up on the knock sensor.
Timing was found to be at base 20 deg. for some reason unbeknowst to me, so he pulled base back to 18.
Still had issues. Hooked up the fuel pressure guage and foung that PSI was dropping from 51 PSI to around 40 at high revs. Looks like the fuel pump is shagged. This will also account for the 12.5\1 fuel ratios that magically happened on the low boost runs.
SO, we actually added more fuel in at the top. I'll need to go back after the fuel pump is replaced to retune the top end.
The DFA seemed to work really well in what it was suppose to do.
A couple of extra things I found was that I hooked up a Ford EL o2 sensor half a week ago and the tuner said it wouldn't work as he had a 32 that came in with the same thing and it didn't work - however, when we plugged in the laptop and checked out the sensor reading it was working. AFR's on his sensor were good too. So there's one myth busted. Mind you, It's probably different between models. Mine's a Series 1 R33.
The other was the flames that were coming out the back on high boost. Looked good, but I've no idea if it was good or bad for the car!!
All in all, it was a fun day.. No hard reving for me though until the fuel pump is replaced.
Dyno graph is attached. He says his dyno read 10% lower than normal..
Looks to be about 170rwkws.
Hey All,
-High boost run
That's a pretty nice ~25 rwhp gain from 3,000 rpm up to almost 6,000 rpm. Must feel much quicker right in the meat of the commonly used rpm range.
Yep, adding some fuel low down is very common. I think it is needed because of the usual efficiency improvements, larger exhaust, air filter, freer flowing cat and intercooler etc. But I reckon the main reason is, Nissan tunes them for minimum emmisions, hence lean as possible where it is safe (off boost). When you are going for the best power, emmissions is no longer a limiting factor.
:rolleyes: cheers :)
Edited by Sydneykid
:D cheers :)
Yer, he had 2 dials on his software that he had to match. I think one was the ECUs target and the other was the calculation of the afr, and he said that because they didn't match, the ecu's fuel trim was adding fuel to compensate (?) (got no idea hey... :) ) Interesting though...
This is one informative thread!!
A big thank you to you Sydneykid - you have answered so many q's in heaps of depth!
Now for mine :angry: !!
If you could help me out here it would be appreciated. I am looking at using one of these IBC's but I am not applying this to a skyline - since however you (and so many others now) have such a great understanding of this device, along with the DFA, I am hoping you can help me out...
I am building a turbo 202 (yes it is a bl00dy holden!!) which has the old style k-jetronic (however you spell it) efi system on it, so the injectors all fire at the same time and it also just uses an air flow meter.
Do you think this IBC will still work ok since it is designed to sit on only one injector? From what I understand about the system I will be using the injectors will still fire at the same rate as any given injector in a multi point injection system so I am presuming it will work?
Any advice would be appreciated....
Void
Now for mine :D !!
Void
Oh my, a red motor, I owned one of those......once.......
The IEBC should work, it only needs a trigger signal that varies in length (gets longer) with engine load. Maybe stick a cro on it first, just to check what the injector signal looks like.
:( cheers :)
:D cheers :D
Cheers mate - thanks.
Oh and for your information it is a BLACK motor!!! not a snotty little red :D hehe..
Just a simple question about wiring the solenoid to the IEBC - does the IEBC ground the wire connected to the solenoid, in the same way as the ECU normally does to open it? Or does the solenoid need to be rewired so the IEBC operates it via a positive signal, rather than an earth?
:D cheers :(
Isn't it the other way around? If all settings are at 0 the solenoid will stay closed, therefore the wastegate will see zero boost, therefore boost will hit maximum?
I would have thought all settings would need to be at 100%.......
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
