  • Replies 84
fatz,
I've been looking at a few compressor maps (GT35 .50 a/r)
It appears if you run 20psi you will run over the choke line with anything over 7000-7500rpm on a rb26.
Playing with airflow figures from the 4ltr I can see (i think) why this turbo was selected.
Thats providing I know what I am doing. Still getting the hang of it. :(
Going by what I can see, I would expect power to either flatten out (lack of efficiency = hot air) and or boost to drop off at the top end. It will be interesting to see really what happens.
who knows but hey ill try
dyno dynamics..
could be my fault i just assumed thats what it was... (i dont know shit form clay when it comes to dynos its only the second time i have been near one)
but here is a more accurate test
down the main straight a oran park racing with a gibson hr31 which has 270rwkw he pulled about 3 car lengths on me (he weigh in about 200-300kg less)... then at the end of the straight he hit the breaks and i almost went up his bum man what a rush driving along side those beasts loved it...
Cubes , would be very interested to see the compressor map of the GT40 comp in .50 E cover . Any chance of posting it ?
Thanks A .
I was looking at a GT35 .50 comp map.
I am a little confused at the moment as the GT35 uses a GT40 model comp wheel.
I've checked out a GT40 comp map with a .58 comp cover which is as close as I can get, the map is much better suited and allows 20psi right up until 8500 with around 55lb/min worth of air before it begins to choke. BUT this comp map was using a slightly larger comp cover so choking may begin at around 8000rpm.
Garret don't list a GT40 with the ford specs (exhaust a/r & comp cover), that doesn't mean it isn't a custom job.
Garret do list a GT35 with the exact ford turbo specs (.50 comp over and 1.05a/r exhaust a/r). Being the GT35 uses a GT40 model wheel could it be this?
If you were to use the GT40, 20psi & an RB26 that were to rev to 10,000rpm it would completely use the comp map (max 63lb/min).
An RB30DET would need 8500rpm & 20psi to flow the same air.
I'm sure it will keep making power as it goes in to choke as these little stock T3 turbos must be constantly in choke from anything above 5500rpm lol. :)
Too hard basket. :(
Discopotato, the pdf can be dloaded from Garrett.
Fatz... If you can get the rev's/airflow via cams I can see 340rwkw.. :)
by all acounts it should flow some more
who knows....the boost went to 1.2 bar at 5000 rpm it made almost 270 then before greg stoped to turn it down abit
ill get a power fc and let greg loose with some injectors ect and some cams athen we will see what it can do
dont really know just happy with it as is at the moment
Joel its not difficult to be confused with Garretts PDF . I think the maps of the GT32 and GT40 may be describing bush bearing turbos . In that list GT30R and GT35R , I think the "R" denotes GT series Ball Bearing CHRA . If you looked at the GT42 it shows the optional BB CHRA .
With the comp covers the maps don't tell if they are TO4E or TO4S . I know for sure that Garrett did the E covers in .50/60/70 ARR's where the TO4S ARR's are all over the place with odd ball no's to suit diesel apps .
The 50 E cover would not have any meat left over with an 82mm compressor in it . Ford would have looked into the maximum flow of the cover and probably decided it was enough for 240KW (crank) with effectivly the 4 psi that makes it to the inlet manifold . Brett tells me that 6psi leaves the compressor and 4psi leaves the intercooler .
I reckon looking at the large 1.06 ARR turbine housing and adequate ? comp cover Ford were trying hard to have little restriction on the exhaust side , and just enough inlet flow to get the power rating .
Garrett and Ford would have the compressor map for this combination but getting it out of them would be difficult .
As an RB bolt on these should be pretty good , its just a pity Garrett haven't done the .82 turbine housings as well .
It will be interesting to see the actual numbers.. 5psi doesn't sound like much but it may very well prove to give a nice increase in power with the ol' rb at low rev's.
I'm about to select a comp cover for my turbo so I need to do a bit of reading up on these TO4E and TO4S comp covers.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
