  • Replies 84
Fatz you do have a couple of options here , first is to replace the .50 ARR comp cover with the larger .70 ARR T04E cover and keep the backplate .
Second is to use the larger series T04S cover and backplate (adapter ring) which is what Garrett did with their GT3540R turbocharger .
If your finances are limited go the larger ARR .70 "E" cover . If the sky is your limit go the "S" bits . Also remember that the T04S covers are quite large so make sure there's enough real estate where your turbo lives .
Generally compressor covers are sized around airflow rates or speed . So for a given compressor wheel the larger the Area Radius Ratio the lower the gas speed will be and vice versa . Also the larger it is the less chance it will have of being a choke point at high wheel speeds . Someone did tell me that all else being equal going up in comp cover AR brings the boost on a little later and "hits" harder .
With most Garrett turbos there is a set compressor wheel diameter for each wheel/cover family , ie 60mm wheels T3 covers , 71mm wheels T04B covers , 76mm wheels T04E covers , 82mm wheels T04S covers .
In recent years Garrett started going up a size in cover with some of the GT BB series compressors . I think this is because the comp wheels are mechanically stronger , and and can still pump efficiently at much higher rpm's than the bush bearing has beens . This is a win win situation , the small high speed wheels are compact , cheap to produce and more importantly have less innertia so spool sooner .
Examples of this are the little GT28RS (T04B comp cover) and some of the GT2835R series turbos with 71mm compressors and T04E covers .
The Garrett people inthe US tell me that the up sized cover , and a little extra tip height on the wheel , gives extra pumping capacity and a few more points compressor efficiency .
I can only think of two examples of Garrett turbos that went smaller in cover size , they are the HKS GT2540 and the Ford GT3540R . The 2540 is getting on and was probably an attempt to get a bit more flow and power out of a small series turbo , and a low mount compact (convienent) fit for GTR's .
Its safe to say Ford was not looking for serious performance with the XR6T so a compact and probably cheaper adequate cover got the nod . You can bet they knew people would modify them for performance , so the limited cover capacity may have been intended to limit the performance with the std turbo but not affect the standard state of tune .
Cheers A .
yea just stuck a side pipe on the beast and took it out to the drift day
sadly budget has died in the arse so i will have to putt around for some time until a set of cam gears arrive and the powerfc which is probably about 3 months away
im quite happy with the power but as soon as those cam gears are in hopefull it will bring it on a bit better
if cam gears dont bring it down to 4000rpm with power fc and a decent tune then i will consider the upgrade to external wastegate and a .86 rear housing and combine it with the larger front cover
but hey im happy as a pig in shit at the moment and when i win lotto ill do the next big upgrade
ive also got a rb30 complete engine that will be getting a solid bottom end over the next few years to replace the gtr bottom end when or if it ever goes
yea baby
anyone have some cheap cam gears
pete
  • 5 weeks later...
  • 2 months later...
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
