With new colour themes, can we please make sure that the TICKS next to forum names on the main list contrast with each other?
At the moment, it's impossible to tell which forums have new posts cos both ticks look the same :)
Merli. :P
yep - i saw ryans designs - i think they look great! - should use them! - and if hes already got them in the right format then would it only be a matter of changing the skin on the forum or something? - surely the part that take the most time is the actual construction that ryans already done?
hey guys,
The forum colours are currently number 90,000 on my 'to do' list.
Eventually (and i do mean 'EVENTUALLY') there will be several styles for you guys to choose yourselves when you log in.
Christian
NO DO IT NOW NOOOOWWWW NOOOOOOOOOOOOOOOOOOOOOOOOOWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
thanks prank u rule :Dz
Christian: Let someone else look after it then... You don't have to do it all you know!!!! There are heaps of people who will help you out if you just ask for it...
/me looks around.... Hmmmm
Merli. :P
P.S. This place is looking good... Keep up the good work!
If people would like to create a style, thats fine - by all means, go ahead. Email them to [email protected]. But I wont give access to anybody to change the current style. The only people currently with that access are admin's, and for the moment, it'll stay that way.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
