Mark Posted January 17, 2005 Share Posted January 17, 2005 Well today is the day I enter the well trodden path of registering an import. I have my inspection at 1:30 today. I would be lying if I said I wasn't nervous. I'm starting the day with a wash of the car and vacumn. I'm hoping the nicer the car looks, the less chance of failing there is (fools gold I know). I shall report after the actual inspection with tales that will chill your blood, turn your wine to water and make you want to buy an aus delivered car! :bs!: Mark - The not so chosen one. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/ Share on other sites More sharing options...
Amaru Posted January 17, 2005 Share Posted January 17, 2005 Youre gonna fail Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165371 Share on other sites More sharing options...
Sinista32 Posted January 18, 2005 Share Posted January 18, 2005 Hey Mark - Get Funky with em if their Nasty.....Darlin Bahahahahaha I might cruise down for a laff and point out all the bad bits they might miss.. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165493 Share on other sites More sharing options...
Terminal Posted January 18, 2005 Share Posted January 18, 2005 I've heard it's better to have heaps wrong than a few things, because if there's heaps wrong, and they're easy fixes, they probably overlook the bigger problems which are less obvious and harder to fix. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165507 Share on other sites More sharing options...
MYSHY32 Posted January 18, 2005 Share Posted January 18, 2005 The three main thing I have always had trouble with are. Ride height. Dirty or oil underneath Exhaust noise If your ontopof those its a good start. Daniel Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165527 Share on other sites More sharing options...
Amaru Posted January 18, 2005 Share Posted January 18, 2005 The cars bog stock but 15yo import so he shouldnt have too much hassle, its a very clean and tidy car Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165534 Share on other sites More sharing options...
Shell Posted January 18, 2005 Share Posted January 18, 2005 Good luck Mark! Hope u get the really old guy (if he's still there) he was nice to me Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165655 Share on other sites More sharing options...
MIVEC Posted January 18, 2005 Share Posted January 18, 2005 Take it to Jacko's - they're just across the road from the Dickson Pits and do NRMA inspections. I took my car there and passed easy. Then just walk across the road to the registry and you're done! Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165696 Share on other sites More sharing options...
GTS_DUY Posted January 18, 2005 Share Posted January 18, 2005 mivec u must be thinking of road worthy certificates (RWC) - for transferring registrations and stuff Mark has to go thru the pits...a bit different, and harder. gl mark, sell me your cooler! Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165728 Share on other sites More sharing options...
JD_R33 Posted January 18, 2005 Share Posted January 18, 2005 mivec u must be thinking of road worthy certificates (RWC) - for transferring registrations and stuffMark has to go thru the pits...a bit different, and harder. gl mark, sell me your cooler! Ummm, I think Mivec is actually right - when I got my R33 registered in the ACT the motor registry people told me that I could get a mechanical inspection done at any authorised inspection station, but only Dickson could do the "identity check" which is required when transferring a privately owned vehicle from another state. I think Dickson used to do all import mech inspections, but that changed some time ago. I decided to kill two birds with one stone and get both done the same day at Dickson, but in hindsight if I hadn't been doing the id check would have definitely gone elsewhere for the normal inspection. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165747 Share on other sites More sharing options...
race_snooze Posted January 18, 2005 Share Posted January 18, 2005 Well good luck with the pits then. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165834 Share on other sites More sharing options...
Amaru Posted January 18, 2005 Share Posted January 18, 2005 The car is a 15 year old import, it has to go over dickson. And talked to Mark not long ago, it was failed as it needs engineering certificate to proove all the complaince items have been installed (as they arnt complianced like normal imports). Also needs steering rack boot or some crap. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165841 Share on other sites More sharing options...
Aurora Posted January 18, 2005 Share Posted January 18, 2005 Gah, that blows Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165850 Share on other sites More sharing options...
tridentt150v Posted January 18, 2005 Share Posted January 18, 2005 Someone to look at your seatbelts and check your dimmer switch then give you a tick in the right box, thats worth $500 not. Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1165960 Share on other sites More sharing options...
Mark Posted January 18, 2005 Author Share Posted January 18, 2005 The car is a 15 year old import, it has to go over dickson.And talked to Mark not long ago, it was failed as it needs engineering certificate to proove all the complaince items have been installed (as they arnt complianced like normal imports). Also needs steering rack boot or some crap. Thank you nik :Bang: Anyway, yes I failed. The three things were: Engineers Certificate Split Steering Arm Boot Oil Leak/s Shell, I did get the old guy, he's a champ. He said "Those twin cams can get pretty expensive *grumble grumble*" . Nicest RTA type fellow I'd ever met. Anyway, I have now got the car booked in tomorrow for the fitting of side intrusion bars (ouch) and fixing the other problems. Engineer should be Thursday and then the reinspection.... Duy, you can buy my cooler when Amaru sells me his haha. Stay tuned for more exiting installments of - "The Dickson Chronicles - The VR4 Affair" :headbang: :bananaman: Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1166033 Share on other sites More sharing options...
Mark Posted January 19, 2005 Author Share Posted January 19, 2005 Update - The saga continues Today, the Side intrusion bars were fitted at a cost of $700. I also met the engineer (John Wilson) and he is having a look sometime this week I beleive.... Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1168241 Share on other sites More sharing options...
GTS_DUY Posted January 19, 2005 Share Posted January 19, 2005 hey mark. when you get your engineers cert from john wilson, chuck us a write up here, or PM me. need to know what he does and exactly what he looks at. andy Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1168701 Share on other sites More sharing options...
MYSHY32 Posted January 19, 2005 Share Posted January 19, 2005 He is pretty relaxed kind of guy and interested in skylines from what I have been told. Just looks for the basics. Ask for photos of your mods in your certificate if there is any? Dan Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1168957 Share on other sites More sharing options...
Mark Posted January 20, 2005 Author Share Posted January 20, 2005 I now have my engineers certificate for $470. I'll post some pics of the things it covers soon. Right now, I have a haircut to attend! Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1169777 Share on other sites More sharing options...
Mark Posted January 20, 2005 Author Share Posted January 20, 2005 Well I took some photos but they are really hard to read, so I"ll just list exactly what he checks: Owners Name Address Rego Number Body Type Monty/year of manufacture Engine number Engine capacity Chassis/Vin number Unladen Mass Odometer reading Engine, tansmission and driveline exhaust seatbelts fromt/rear suspension and axles braking system/steering Wheels and Tyres Side intrusion bars Seating Child restraints Tyre placard Drivers side mirror Centre high point brake lamp suspension hight After all that he says "This vehicle has been modified using correct engineering practices and workmanship. The changes comply with the requirements of the ACT inspection manual for light vehicles. It's performance and handling have not been degraded by the changes and the vhicl is considered safe for use on public raodways" Hell's yeah, ironically, the only picture that turned out was the bill. See attached :Bang: Link to comment https://www.sau.com.au/forums/topic/61757-chronicles-of-dickson-the-vr4-affair/#findComment-1170111 Share on other sites More sharing options...
