Kind of a silly question but im a novice so thought i'd ask on here first.
When driving at night i get alot of people flash there high beams at me (atleast 3/night) for no reason at all.
Im thinking that maybe my headlights are tilted up alittle too high?
Does anyone know what level they should be set to ?
When i had the headlights in my old car replaced the mechanic would stand a certain distance (??) away from the front bumper and make sure the lights were displaying on or around his knee (??)
Anyone know how i can check/adjust the height ? ('95 R33 GTS-T)
/end dumb Q
https://www.sau.com.au/forums/topic/6182-headlights-q/
Originally posted by benm
Tand they are illegal to use when there is no fog (which there isnt in my driving area).
That doesn't seem to stop the majority of tossers out there who have them on their cars.
https://www.sau.com.au/forums/topic/6182-headlights-q/#findComment-92919
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
