Can any of u guys point me towards a good polish to get rid of small chips etc in the car. I don't really want to use a cut and polish too often, how often do you reccommend using a polish.
i use glide on glaze to get a good shine after a wash, but it doesn't get scratches etc out, it is just for shine :) Shine is good :)
https://www.sau.com.au/forums/topic/6197-polish/
use meguiars paint cleaner if u want to take off very very light scratch or marks from the paint. or stains, swirls etc. paint cleaner is good stuff. else use meguiars scratch X, i haven't had the need to use that, but i heard it works pretty well. like a lite cut n polish. i wouldn't use any of this stuff too often. i only use paint cleaner like once every few months.
https://www.sau.com.au/forums/topic/6197-polish/#findComment-93422
Originally posted by MRK25T
What can you use to get out small scratches in a double din head unit to make it look like new again?
Mark
I used toothpaste.. yes, toothpaste! (non-gel kind of course!) It's almost like a VERY fine cream cleanser...
use at own risk tho... i used AIM btw ;)
https://www.sau.com.au/forums/topic/6197-polish/#findComment-93844
Amongst my collection of cleaners and polishes are the following, hopefully this will help you guys
1. Autoglym Super Resin Polish (remove marks and small swirls)
2. Autoglym Glass polish (marks on glass, yes i use on headunit)
3. Meguiars hi tech yellow wax (use after polishing)
4. Meguiars Gold Class Wash (the only wash to use)
5. Meguiars Chamois
6. Meguiars cloth and trim cleaner (EXCELLENT STUFF)
7. Windex
https://www.sau.com.au/forums/topic/6197-polish/#findComment-94358
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
