:cry:  this sucks, think I am out. Guy is picking up my old daily on wednesday, which mean I don't have any car at all that I can drive :D
Can I scum a lift off anybody?
Ide taka ya gordo but dont really wanna drive to the coast and back :(
  • Replies 315
cant wait till thursday it is goin to be mad as
What car you got?
Havent seen you around before i dont think? I live in morningside too pretty much
If you can get down this way ill take ya gordon, but thats a bit of a hike :D
Someone from the coast thats going must be able to help out, cmon guys!
Which exit of the beeneigh motorway do I have to take to get to Aussie pieworld?
We're going to be on channel 7 like always? right?
Exit number 69, and you are looking for Clark's Aussie Pies at Springwood, 500 metres north of BP Coomera, and channel 41 you idjut!
Dude I can't find clark's Aussie pieworld at st Alburns in the phonebook. What gives?
I think my car is a halfcut welded back together. Is this a bad thing?
Not if they actually welded back 2 R33's, I think you have a front R33, a back R33 and a middle cut from a camry! :(
Just make sure you are on channel 41 as you cruise up Gympie rd towards Dreamworld, and call out, "Charly............................Charly......" every couple of seconds and someone will hear you and give you directions to Crazy BP Pies, 500m north of Harry's Diner!
You're bound to find it at www.icantreadamapwherethe****isit.com.au
sweet.
Attention all clueless n00bs. Click the above link and type "I'm freakin useless" into the search field. Then click all the links in the million popup windows that should appear.
If that doesn't work go and buy a refedex and learn to read a map like the rest of us.
I could not get the link, www.icantreadamapwherethe****isit.com.au to work. Just wondering if anyone can tell me where to buy a referdex?
If I can't get a referdex in time, I just drive up and down the highway checking all the channels on my $23 CB and I should find everyone, right?
Everyones a comedian.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
