:cry:  this sucks, think I am out. Guy is picking up my old daily on wednesday, which mean I don't have any car at all that I can drive :D
Can I scum a lift off anybody?
Ide taka ya gordo but dont really wanna drive to the coast and back :(
  • Replies 315
cant wait till thursday it is goin to be mad as
What car you got?
Havent seen you around before i dont think? I live in morningside too pretty much
If you can get down this way ill take ya gordon, but thats a bit of a hike :D
Someone from the coast thats going must be able to help out, cmon guys!
Which exit of the beeneigh motorway do I have to take to get to Aussie pieworld?
We're going to be on channel 7 like always? right?
Exit number 69, and you are looking for Clark's Aussie Pies at Springwood, 500 metres north of BP Coomera, and channel 41 you idjut!
Dude I can't find clark's Aussie pieworld at st Alburns in the phonebook. What gives?
I think my car is a halfcut welded back together. Is this a bad thing?
Not if they actually welded back 2 R33's, I think you have a front R33, a back R33 and a middle cut from a camry! :(
Just make sure you are on channel 41 as you cruise up Gympie rd towards Dreamworld, and call out, "Charly............................Charly......" every couple of seconds and someone will hear you and give you directions to Crazy BP Pies, 500m north of Harry's Diner!
You're bound to find it at www.icantreadamapwherethe****isit.com.au
sweet.
Attention all clueless n00bs. Click the above link and type "I'm freakin useless" into the search field. Then click all the links in the million popup windows that should appear.
If that doesn't work go and buy a refedex and learn to read a map like the rest of us.
I could not get the link, www.icantreadamapwherethe****isit.com.au to work. Just wondering if anyone can tell me where to buy a referdex?
If I can't get a referdex in time, I just drive up and down the highway checking all the channels on my $23 CB and I should find everyone, right?
Everyones a comedian.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
