ok sounds like a dumb question, but what is the going opinion on gearbox oils for a GTR R32 as I have a slight syncro noise on 4th, and was hoping that a better (read more suited to GTR) oil would be the go?
while we are at it GTR power steering fluid? factory only?
https://www.sau.com.au/forums/topic/62295-r32-gtr-gearbox-oil/
I put Redline MTL in my SR20 box and it quietened it upa dn made it shift smoother, I have no idea wether this oil is suited to a GTR< but something of similar qulaity would be good, (it cost me $100 for the oil in the sr box).
got the redline oils from coventrys in mascot.... they have moved to william lane and are tricky to get to, and have all the good stuff for GTRs with the lightweight gearbox oil for $99 the diff 80-140 recommended for $94 and the water wetter for cooler radiators for $20....
so a lot of cash, but will be worth it in the long run!!!
I used castrol vmx80 for my gearbox.
Fixed up my 4th and 5th notchy gearing problem.
Cost - $29.95 4 litres (which was just enough)
Also I used the castrol LSD oils for my front and rear diffs
$ 32.95 for 4 litres with 1 litre spare
I'm very happy with this particular service
so does anyone else run out of gear box oil for the R32? I havent done it yet as the car is still getting the aircon done! 3 days later.... as a side note what will I be up for, for a aircon compressor when they finally tell me! grrrr.... hard not having the car!
DAN00H did you manage to get a full gearbox with the redline?
What do you mean "run out of gear box oil"?
I replaced the gearbox oil in my R32 GT-R a couple of weeks ago with Redline Lightweight Shockproof. I needed about 4.3lts all up: luckily I bought an extra 2 pint bottle (or whatever it is) as it was a three hour round trip to the closest Redline stockist :D
LW.
ok thats what I meant by run out... i.e. I didnt know it was going to need more than the 1 bottle! ouch more expense!!!.... luckily the redline place is not far in mascot....all though I am sure I got the last big bottle! do they make a smaller one also?
cheers.....
