  • Replies 66
Sorry roy... forgot to mention...
You set the scramble to a higher setting for a set amount of time. You can also make it go to a lower setting if you wish. The unit also had a fail setting. If the boost goes over a limit setting then it will go to a lower boost setting for a set amount of time.
EG.
I run 10psi
I have boost fail set to 11psi (this will flash and beep if 11 is reached)
Then it will run 7psi for the next minute.
This has only happened once when the ID-III read hose got crimped by a zip tie. This caused it to over boost and react slowly. All of a sudden i had 12+psi and i was rocketting down the road then there was a beep beep beep and the boost dropped off to stock and i scratched my head. Pulled over and looked at the boost graph and it all made sence.
  • 8 months later...
Can one of the SBC children do me a favour and set their scramble duration to 0 and go for a drive....i need to know if it will use the scramble setting whilst you are holding the button down. Dont want it for a preset duration, want it to activate while i am pressing a button
Dont want to buy the wrong EBC
  • 2 months later...
Mate sorry i totally forgot about this thread until i dug it up for a guy the other day...
I tryed (like 8 months ago) and nothing happened. You set it to 0 and nothing happens when hit scramble...
So there is the answer you have waited almost a year for... LOL
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
