Hi guys
It's time to get rid the standard air intake and get me something a bit better. I have read the threads about the a'pexi power intake and decided it looks the goods, i also am thinking of buying it through www.perfectrun.com.au . They have the a'pexi power intake for $345 (not including freight) for the R32 GT-R, is there anything else i will need to buy? or does that kit include everything for the installation?
Thanks.
https://www.sau.com.au/forums/topic/6264-apexi-power-intake/
Very professional....looking good :D
You need to partition them off so they suck cool air instead of nasty engine bay air.
Just looking at your pics an easy way to do it might be to separate the filters from the adapter tubes and place your partition so it sits against the flange of the tubes, cut holes for the air intakes then use longer bolts to put your filters backon with the partition sandwiched between them and the flanges. would make for a nice simple job. Good luck
https://www.sau.com.au/forums/topic/6264-apexi-power-intake/#findComment-101641
Uas is the only place I know that supplies them and unless your car is stock I don't know how they can get the holes for the pipeing in the right place . I got one and it never even looked like fitting, Best way is to make your own using aluminium backed foam. it's much easier to work with than rigid material and you can close it off completely.
https://www.sau.com.au/forums/topic/6264-apexi-power-intake/#findComment-101758
Originally posted by vspec2
Did the entire kit cost you $345 including piping?
cheers
Plus $82 freight. It came with the brackets and the two pipes for each pod, just unpack and take off the standard airbox, and wack her on, the directions are in japanese but the diagrams were very easy to follow. It took me about 30 minutes to do it and this is my first hands-on mod, so it's not that hard.
https://www.sau.com.au/forums/topic/6264-apexi-power-intake/#findComment-101765
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
