Hey All,
I've just bought myself a gauge set and trying to figure out where to place them in my R33. Does anyone on the forums know the ins and outs of ADR's with respect to gauge fitment on your dash???
Any help or advice is much apprieciated :D
-Ant95gtr
https://www.sau.com.au/forums/topic/62680-advice-on-adr-compliance-gauges/
  • Replies 41
pretty sure as long as they are below the top of the steering wheel they can be mounted anywhere on the dash so as not to restrict your view out the front or side windows.
Thanks Nark........I actually thought this rule read that you can't mount any gauge above where the dash meets the windscreen from the driver's point of view. I know a couple of people who got a bright yellow sticker for mounting it off of the A pillar right where it meets the dash - this would be under the top of the steering wheel but would 'restrict' view out of the bottom rhs of the windscreen......talk about :bs: design rules!
Adz - If you can track down that info it would be great. I have looked at the Vicroads website and the only gauges they provide info on are external ones (spot on Nark :D )
RTFGTR - I think that is the understanding of the rule that I tried to explain in my second post. From the drivers point of view (eyeline) nothing can obstruct the windscreen above the point that the dash *appears* to meet the windscreen.
Yeah it's strange, I can't find it anywhere. I know what it looked like, was a pic of a cluster and dash and had a circle round it showing where gauges can be mounted. You will have to call them I'd say.
I do remember it said you CAN NOT put them on the pillar, on the passengers side dash, ontop of the passenger dash. It said they were ok on the edge of the drivers side and also on the top of the steering wheel (which I think is silly, how do you see the gauges). The general rule is if you can hit it when you crash or if it's blocking your view = Bad.
Maybe even do a search on gauges?
yeah thats pretty much it... i know the singl cluster a pillar ones that were mounted low and in the corner were actually legal... i know where i had mine to the left of the original cluster was legal and was on the top of the dash in a way.
if ur going to get a few of em cut them into the dash itself
Wow thanks for that Adz....thats exactly the kinda info I'm after. I knew about the pillar thing as a mate has been done for it but hadn't heard about the passenger side dash rules etc etc. Makes sense though as in the majority of crashes the driver and passenger will hit the dash at some point so anything added in this area will present a higher risk.
I have done a search in the forums using gauges and other keywords but it seems no-one has 'official' info on where to locate gauges. I have also searched various vicroads websites to try an get this info and it seems the only way to get it is to actually buy the ADRs. I find it very frustrating that cops and vicroads are more than happy to defect us for modifications not complying with ADRs, yet when you try to find the info BEFORE you do the mod to try and ensure that it is legal, its impossible to find......
.....I guess the vic govt doesn't want to miss out on all that revenue huh :P
Yeah trouble is you can't fit 3 gauges where the a pillar meets the dash :P
the whole reason for this thread is 'cause I'm weighing up whether to fit them on the a-pillar /top of dash combo (and therefore for easy removal) or to cut them into the dash.
At this point, and with the lack of official info I'm leaning towards the dash option....the only thing I'm worried about is that I want to try and make it look as OEM as possible which means tracking down some higher quality single DIN fillers....any ideas on where I can find 'em??
yeah I'm kinda after a 'fill' plate. Basically I have an equalizer in one of my din slots that isn't being used.....I was thinking of ripping that out, replacing it with a fill plate as close to the face of the dash as possible, then cutting the gauges into that (and a bit of the dash surround around the din slots). To make it look as OEM as possible I was hoping to get either a CF or black plastic fill plate for a std din slot (i assume it would screw into the same screw holes that the radios use)
i love the look like the ones in my old ceffy were...
i'll be doing the same with my next car and cutting holes in the glovebox side of the dash and tilting them towards me....
Yeah Ni I didn't mind the look of those dash mounted gauges in the ol' girl......well except for the 'extra' air con vent :P
I considered that posi but with my eyes the way they are the closer to my driving position the better :P
hahahaha yeah Ni any ideas on where to find 21" gauges that I can read from the drivers side????
Unfortunately the aircon vent is similar to the centre dash ones.....squareish with one side sloping down.....Anyway I'm going to have a chat with a shop this week to try and get this sorted as not knowing the temp my oils getting to on track days is playing on my mind.....
If I get any ADR info while doing this I'll post for others...
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
