Actually Dragzz, if you install the system yourself $350 is more than enough money for a 3point immobiliser, alarm and keyless entry. take a look at some of the recent articles on Autospeed.com about alarms on a budget.
The plastic thing on your keyring wont look as pretty as a $600 one but it will do the same job and cost you less.
Also, I've been reading those autospeed articles on the alarms and I fail to see what the difference is between like $1000 alarms and the $150 jaycar jobbies.
Can anyone enlighten me please?
Let's see the $1000 alarms would have:
Immobiliser 3points +
Alarm
Tilt sensor
Bonnet/boot sensor
Black wiring
Keyless entry
Maybe GPS & Keypad
$150 jaycar jobbies:
Alarm
Immobiliser 2 points (?)
$1200 Fitted and you can get the best protection , a tracker .
Who cares how many points you have they can easily be bypassed by experts , at least with the tracker you can immobilise the car as soon as the move it and you know where it is at all times , unless underground .
  • 1 month later...
Extra features available int he alarm, software programming and more inputs with different polarities is generally the difference between the cheaper adn the more expensive alarms, I am more inclined to pick up a more expensive alarm than a cheaper one as I generally use the extra options and features..
I also fit the alarms myself, I used to a lot of car installs for work, so alarms are a walk in the park for me.
Do you have any recommendations then yorik?
I'd like to have -
remote central
3 point immobiliser
extra inputs for tilt/boot/bonnet
siren output (not just horn)
black wiring
good code hopping
It'd be a bonus if it had auto arming, have silent arm/disarm and be able to lock the doors even when the engine was on (for warming the car up).
Cheers.
Hi Guys,
I need to find out what is a pretty good alarm system (upto about $350).
It is a must because of insurance.
Do you guys have any reccomendations??
Dragzz :headspin:
If your insurance company requires you to have an alarm installed, it is very important for you to get them to tell you which alarms are suitable.
Thanks chunners.
Funny enough I saw the "BW10000" on ebay also http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...ssPageName=WDVW
$170 is better than $250.
One thing did strike me as odd that the blackwidow webpage (www.blackwidow.com.au) doesn't list how many immobilisers it has.
I might end up just paying the guy who did my flatmates r32 the $400 he's askin to do the lot with the whizz bang system he reckons is best.
I'll think about it then and update the thread with my thoughts if I have any feedback worth giving :)
Cheers.
autowatch, brant, viper and mongoose are the only alarms that i'd ever have in my car. i had a warlock before and it was shit.
reliability, features, compliance to au/nz standards and actually PROTECTION from thieves are there in spades with the right alarm. a $100 jaycar job is a walk in the park to get around. i watched a guy do it at a place i used to work at and it was just too easy for him! (hifi store).
but as they say, an alarm is only as good as its installer. a stratties job may very well be fine, but they install it with hotmelt and wishful thinking, your better off leaving the keys in the ignition.
d
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
