So far i just know that the R32 RB25de and R33 RB25de came with the 5 speed auto. I'm not sure if all of them did.
My HCR32 has a 5 speed auto.
It has 3 gear selections on the shifter and then 2 other gears on overdrive.
The overdrive sucks because when I'm driving Miss Daisy in the back and select OD after 80kmh, both 4th & 5th gear shift within a couple of seconds and the next thing I know I'm doing 80kmh with the engine turning at 1500rpm - needless to say it's pretty bloody gutless down there in that rev range. But when I'm on her she'll swap into 4th at 150kmh and 5th at 190kmh.
My only real bugbear is the inability to select 4th and 5th at will, which is why I'm in the middle of procuring everything for my manual conversion, no more auto for me.
I saw a five speed in a non turbo rb20de R33.... 4 door.....
I thought it was very strange as the dash in the 33 has the gear selection lights it had 1-4 then drive... a normal auto r33 had 1-3 then drive...
I dont know where youd get that info other than nissan japan... I have only ever seen one myself and i was confussed... I spoke to the guys in our auto devision and they had never seen one nor did they have any tech info on this box....
Yeah putting a manual box in a standard auot is a good thing...
I did it in my old GTSX.... The diff ration is taller and makes for a faster acc but lower top speed... But top speed is not important at QLD raceway nor on the strip as you will never reach red line top gear..... So yes this is a great idea....
Nissan had the 5-speed auto transmission designated RE5R01A, it's sister to the 4-speed, the RE4R01A and was used in both the Skyline series and the 1999 Q45 4.1 V8 Infinity, although there are other vehicles, I can't remember exactly which ones.
The manual coversion is going to be a wait and see as the gearbox I have coming is a Nismo close ratio, so the diff ratio may be a bit extreme for the box, should be fun for a while though!
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
