  • Replies 69
Lauren ...... it think its time to enforce our corporations SONGOP MJ&L Corp and McKeon & Associates upon this evil so called "council". For with our mighty power we WILL take over the WORLD woooohahahahahah.
OMG we sound like Power Puff Girls! :run:
Aha
your plan has been discovered and duly legislated against here ....
http://www.skylinesaustralia.com/forums/sh...?t=63877&page=4
Post 88 onwards.
  • 1 month later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
