Hi guys
Im contemplating throwing nos into my car cause i can get a real good deal on any HP shot (full system) OZ NOS setup?
MY rb25det, is pretty stock @ the moment (internals) other than 3" turbo back, fmic, ems, 550cc injectors, fuek pump etc...
What HP do you guys recommend, & if so, what should i have done to the motor to not fry itself...???
& I wont be using it much @ all, only on the track once or 3 times etc...
https://www.sau.com.au/forums/topic/62812-nos-system-wetdry-for-rb25det/
Single fogger wet system, running a 50 shot I think or a 75 hahaha one or the other, be careful though the oz nos system looks like good value but when a NOS brand single fogger wet system is only $850 now with a 10lb bottle its hard to go past as the oz nos comes with no bottle
Brett
Brett
say i buy the real "NOS holley" setup , with everything....is it still cool to hook it up & use it only once every while? like @ drags etc.,.
& being in nsw, can i cruise around & not get done by cops as long as i dont have the bottle in the car yea?
Mate its the single fogger wet system you need as the holley set up is for a carby, yep as long as the bottle isn't in the car you'll be fine and yep its fine to use every now and then you might just need a after market ecu to be able to take a couple of degrees of timing out if you plan on running anything bigger then a 50 shot
All testing should be done on a dyno though to check if it needs it or not
Holly make systems for Fuel injected cars as well as carby systems.
You shouldnt need an aftermarket ECU, just set the mix correctly.
Correct me if im wrong, But if your running 550cc injectors should your car have an aftermarket ecu? It would be over fuelling to the shithouse as the the stock ecu is already programmed to run rich mixtures?
Is it really that safe running NOS without Aftermarket PIstons?
Is it safe to increase boost without aftermarket pistons ?
There comes a point for any engine where enough is enough. The rb25det seems to be OK up to 250rwkw, so an extra 75hp of NOS at this point might be pushing it too far, but if you are only putting out 150-200rwkw, then a shot of NOS is probably your cheapest way to get that much power.
if you can use a diffrent brand it would be ok.
i had a faulty nos solanoid with my very first nos setup . it was a OZNOS type wetkit and the nos solonoid didnt shut so even though i had the switch of it was still throwing nos into the motor :( lucky i had a passanger that could reach the bottle and turn it off.
since then i have had two NOS BRAND kits and never once had a problem.
good luck with what ever you end up doing.
Hey guys - dirty-cheaterer-pusseh here :(
I run a 75hp NOS brand wet nitrous system using a single fogger plumbed between the factory BOV location and the throttle body.
It works great. Boostn247, dude, just come to myhouse and have a look. Bring your notepad and a pen ;) Gimme a buzz - 0416271834
Adrian
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
