Automatic Transmission Shift Kit. - Updated Oct 2006
I got my package today and if everything works out it'll be in on the weekend.
I'll keep you all posted.
Also, I've started a new thread about possible gearbox problems i'm having.
Any help will be appreciated. Thanx.
http://www.skylinesaustralia.com/forums/sh...686#post1224686
standard cooler is tiny, about 1/3 of the upgrade
for those curious people
here's a pic of the MV cooler upgrade
got it today with the new valvebody
Awesome, ill be getting one of those too
Shift kit is in!
definitely tighter shifts... but a bit more brutal in my case since Ive got a wolf in as well, still within reason though
Will be sending valvebody back real soon
tomorrow or day after, its still soaked in oil
The trans-cooler also went in, too bad had to mount it between radiator and FMIC (stock location) would have preffered a better location.
So is it gentle at lower speeds still?  Can you please give us a more detailed description lukits?
At lower speeds it shifts like factory, I couldn't really feel any difference. But at high rpm, shifts are definitely more jerky, chirps the back wheels a bit in my case
Any figures on how much power the auto box can handle now with the shift kit and trans cooler?
My tuner has very little faith in them...
I beleive mike himself on zoom mag said 'With a good condition box and one of my shift kits.. 300kw)
Im about to call MV auto now and get things rolling
Also, did you install yourself lukits?
What about next to the pasenger side wheel well behind front clip where there is a slotted panel behind old IC (at least on GTS -Make some if not)? At least the air will be cooler going through it. A Fan would help as well.
No I didnt try to mount the valvebody or trans cooler myself
I dont think the lines that come with the trans cooler is long enough to have it mounted on the passenger side and besides my intercooler piping sorta blocks the airway from the front bumper slightly
i want 1 in about 1-2 weeks with service kit
Any other Gold Coast people wanna have it done at the same time to save on postage ?????
Called mv the other day and made an order, just waiting for some ppl to send their valvebodies back before he can send anymore out
my auto is starting to play up a little in 3rd gear, occasionally it drops down as if it was in neutral.. asked mike about it and he says its something to do with the engine or trans brake and it should be ok
still, im a bit picky and like everything to be perfect :wassup:
either way i have another auto sitting at my dads house ready to go in if this one breaks :(
anyone who needs somewhere to go in brisbane for auto work.. apparently Athena Automatics are pretty good, had a mate take his auto 180 there with a blown box and with a box he supplied they changed them for $2xx
ide imagine fitting a valvebody + full flush and new fluid (depending on fluid, i use full synthetic = $45 per 4L) wouldnt cost more than $100 max at an automatic specialist
everyone post up how their install went and details so the rest can be informed :P
also, has anyone actually broken their auto and have a new one put it or work done on it?
Sent valvebody back to MV yesterday
Ive used my shift kitted auto-box to the max yesterday from standing start to 6-7k rpm on 4th gear. It shifts nicely at full throttle even with wolf3d. My tyres are crap so it takes a bit of throttle control when shifting from 1st to 2nd to maintain traction.
But ive seem to have a problem with the geearbox computer, often esspecially when its warm, it shifts gears too early. In one run I would go up to 5000rpm and it would shift, other times at 5500, 6000, 6500. Any ideas why the auto box wont shift at 7000 all the time?
Have you tried using the POWER shift button?
I just read your post again and noticed you're using Wolf3D. I'd say that's whats causing the problem for you. The aftermarket computers don't work well with Auto boxes. They are no designed to comunicate with the Auto ECU.
The normal Auto computer has to comunicate to the main ECU. There's a few wires between them. The Auto computer retrives the speed and rev signals. Not sure about the rest.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
