ok its coming up onto the 200,000k mark and the motor is still boosting fine and running great. now my friend said when he does the belt he wants to change the front crank seal and the cam seals aswell. first thing - do you have to do them? is it better if you do and secondly how much do they cost?
any help on the subject would be great.
Thanks
https://www.sau.com.au/forums/topic/62916-2nd-timing-belt-need-some-help/
The seals are the same as the RB30/VL/R31 cam seals. (The oil pump also uses the same seal as the camshafts)
About $6.50 each.
If you want genuine you will pay around $15 each.
And as mentioned, do the water pump as well.
Im fairly sure the RB20 has the same pump bolt spacing as the local VL/R31. (The RB25 is different though)
Therfore you can get an aftermarket pump for around $88 (PowerMax brand - Made in Japan)
Genuine pump will be around $120.
Its a good idea to do the seals as they go hard overtime and score the crank and camshafts, this is what causes leaks on high km motors. To do the oil pump seal, you would have to remove the crank timing gear, which is a real bitch, often you have to split them and get a new one in order not to damage the oil pump ($49 for a new timing gear).
You should be able to do the oil pump seal without removing the pump itself. If you remove the oil pump, you have to drop the sump.
Hope that helps some.
cool. well i don't need a new water pump as i had one installed not long ago.. so with the crank seal thats the same as the rb30/R31/vl and what about the cam seals? same as all the other twin cam rb's
thanks for you input guys! :(
Just get genuine ones. You'll thank me later. If you go aftermarket you compromise quality with THIS particular product. Trust me I've been there. Three times now.
It's only a few dollars more and you can just give Nissan you VIN and tell them what you want.
The other thing is, when and where is your mate doing these seals. I wanna come and watch to see how he'll get the lower timing belt pulley off to get at the seal. With that particular seal, make sure you have all the equipment to remove it properly before starting coz if you don't, chances are you'll wreck something. Unless you know for sure that it will come off easily. I only say this coz usually it takes an oxy, a couple of big levers, a big hammer, a grinder, a claw puller, a brand new pulley in the end and every swear word you and your mate knows to get it. Let's just say that the neigbours will learn a few new ones. lol.
Good luck.
umm..... well.. i think i might just ask him if he knows what he's into.. he is a very knowledgable person that works in the industry but hasn't worked on a rb but everything else. lol... neigbours.. who needs em lol
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
