Hey guys,
any of you had worked an L20 or know anything about em? Looking at doing one up and I'm curious what sort of hp i can expect etc.
Thinking about stroking it with a z24 crank etc too, but that might be down the track a little.
the plan to start with is headwork, valves/springs, cam, extractors, zorst, twin webbers. if I can find some webbers at a reasonable price that is! haha
Thanks
https://www.sau.com.au/forums/topic/63054-l20b-mods/
hmmm, www.ozdat.com is definately the place for these questions...
personally I think you could spend your money on better engines these days, the l20 was great for its time but is very out of date now....eg a ca18det half cut would be under $1500....
The only question I can answer for sure is the z24 crank can be fitted but it does require some light machining to the block for clearance, as well as limiting the revs significantly.
From my research a pair of webbers and a lumpy cam is the most common place to start but that would still be 800+
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1188353
L18 head onto L20 block raises the comp ratio, combined with higher lift/duration cams & redrilled/reneedled twin Hitachi SU's from the SSS + extractors is a very cheap power up combo, hunt around wrecking yards for the parts.
If you want more from the L20 - you'll reach the point of diminishing returns, and Duncan's suggestion is spot on
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1188761
yeah thats the thing really, how far do i really want to go. But as long as it goes ok, and doesn't really cost a bundle, I think thats what i want. i have a DR that I'd much rather spend the money on really. A ca18 front cut would be good..but theres all the other costs like engineering and dicking around with it etc the bother me.
But under 1500 is mighty tempting. I'd love to build the l20 with huge compression and cam and whatnot though, just for fun :D Oh, and its the missus' car, and I don't want it faster than mine :)
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1189780
apparently the stroke is a fair bit longer, sorry I don't have the exact dimensions here. the 200b standard is good to 7200ish but the navara tops out at about 5500 :D
One other suggestion.....find someone who has already been through this and built a great l20....and then got pissed off and bought a turbo motor instead....nice and cheap to pick up the whole thing with a bit of luck
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1190164
L20B is a great sounding engine on full song with webers. Its a great old skool engine and such deserves this respect. I had one, but it went like crap. But you can make good horsepower out of these engines. Ive seen 200 rwkW with standard rods, actually standard everything with just forgies running like 30psi. But ask yourself: are you after horsepower reliably, or are you wanting to build a classic? The L20 is a piece of sh#$ compared to the CA or SR and would not even touch an FJ. These latter 2 can make 200rwKw reliably at 14 psi and not that expensive to build. Changing cranks, blah blah blah, what for, to geet beaten by a 1600 with a stock N/A CA18??? Not worth it and you'll be the one biting your fingers when you lose. However, if you are after that particular L20-with-weber sounds and wanting a classic, then go right ahead. Classics rock, but Im preformance biased.
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1190207
Well this is the wifes car, she wants it to be a bit grumpy, actually she wants it really really angry, and i reckon it'd be a bit of fun. I like the L18 head idea that someone mentioned earlier, sounds like a nice easy way of getting some decent compression. In a bluebird it'd still be reasonably quick I'd reckon, and if some little punk beats me with a stock ca18, oh well. The skylines for sorting them out :(
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1192602
I have had a mate of mine stroke his l20 out to a 2.4l with extractors webbers, the thing was nuts, lots and lots or touque, rev range was still good, these motors are just about unbreakable, keep the oil and water up to them if they leak and they will go for ever.
I also had my dat 1600 with an l20 twin webbers and exaust they go really well, but one down fall of webbers is that you have to tune the prick all the time.
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1192634
well..I've scored a factory nissan head with all the porting and stuff done for an L20, big cam and some 42mm webers, so i guess that helps out a lot.
The guy I know that ran the stroker motor got 9k rpm out of it, and it was there a lot cause they were racing off road with it. I have access to a machined 2.4 crank and bored block if I want them too. He did say the rear main used to leak a little due to cracnk and lock flex at those revs..but you've gotta expect that I suppose :)
I looked into the closed chamber L18 heads, apparently they're the sss heads that everone wants, and therefor no one can get :) oh well.
https://www.sau.com.au/forums/topic/63054-l20b-mods/#findComment-1194147
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
