  • Replies 184
Guest two.06l
Paul are you all G'd up for sat?
I'll be there but only watching as i know our car would spit a gear box if we push it much harder.
Also whats the Quickest time you have run so far? I'm sure that will get slashed on sat though.
Cheers
gotta instal a tailshaft loop...WTF...these ANDRA tech inspectors are starting to p1ss me off. Not g'd up...absolutely exhausted from prepping car. Quickest time...ive never driven the car so the quickest time will be easy to beat.
Guest two.06l
Are you getting the car tech inspected by Saturday?
Tailshaft loop, scatter shield, race suit and boots ;)
scatter shield...check
6 point cage...check
ANDRA UDL licence...check
vehicle log book...check
battery isolation switch...check
5 point harness...check
arm restraints...check
helmet...check
race suit...check
red racing boots...check
and then the bastard tells me ive got no tailshaft loop.
guess who's going to be busy tomm.
Guest two.06l
The one you told me about at Powercruise
yeah we got dudded...Stace picked up the box yesterday, brought it to the workshop. Guess what we found inside when we split the case.....the most thrashed STANDARD R32 GTR box ive ever seen (besides the one i smashed at the creek)...third gear had nearly every second tooth chipped and second wasnt too crash hot either. NOT HAPPY JAN!
So in true "team twoogle" DIRTgarage style we built ourselves a semi-decent..(if there is such a thing) std box out of the parts we had available. Hell we even have a reverse gear now.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
