  • Replies 184
Guest two.06l
Paul are you all G'd up for sat?
I'll be there but only watching as i know our car would spit a gear box if we push it much harder.
Also whats the Quickest time you have run so far? I'm sure that will get slashed on sat though.
Cheers
gotta instal a tailshaft loop...WTF...these ANDRA tech inspectors are starting to p1ss me off. Not g'd up...absolutely exhausted from prepping car. Quickest time...ive never driven the car so the quickest time will be easy to beat.
Guest two.06l
Are you getting the car tech inspected by Saturday?
Tailshaft loop, scatter shield, race suit and boots ;)
scatter shield...check
6 point cage...check
ANDRA UDL licence...check
vehicle log book...check
battery isolation switch...check
5 point harness...check
arm restraints...check
helmet...check
race suit...check
red racing boots...check
and then the bastard tells me ive got no tailshaft loop.
guess who's going to be busy tomm.
Guest two.06l
The one you told me about at Powercruise
yeah we got dudded...Stace picked up the box yesterday, brought it to the workshop. Guess what we found inside when we split the case.....the most thrashed STANDARD R32 GTR box ive ever seen (besides the one i smashed at the creek)...third gear had nearly every second tooth chipped and second wasnt too crash hot either. NOT HAPPY JAN!
So in true "team twoogle" DIRTgarage style we built ourselves a semi-decent..(if there is such a thing) std box out of the parts we had available. Hell we even have a reverse gear now.
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
