just checking my average fuel consumption... i get maybe 300km to a tank (well full to empty which seems to be about 50L).. so about 6km/L.
mods i have are as follows...
microtech LT-12 ECU,
arc front mount intercooler,
hks boost guage + turbo timer,
twin plate clutch,
open air pod,
turbosmart bov,
3 1/2" straight through exhaust 4" tip.
dyno shows 200rwkW
when i bought the car i was told the ecu had just had a stock fuel map put on it due to lack of time, but it runs really rich.. so much that the back of my car has a black dusting on it less than a week after washing it, and you can smell the fuel wafting past as you stop at intersections and whatnot...
im guessing this isnt all too good fuel consumption, so getting the ecu remapped would be the only solution?
if so.. who/what/when/how much $$$ would i be looking at to get this rectified.
cheers in advance :P
https://www.sau.com.au/forums/topic/63366-fuel-consumption/
Im told Microtech's don't have closed loop, so even when cruising you would be using shitloads of fuel, if so then that's part of your problem
Maybe it's they way you drive :P when I first got my car a caned it and wondered why I was getting such crap economy. Months later when I drove much more sedately and was getting better economy, I realised why.
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1192427
its actually stayed the same wether i thrash it or not (well.. mostly anyway)
there is a serious flat spot at the start of first gear, dumps a shitload of fuel, then takes off... can see it more prominently when you go to do a quick takeoff.. jumps off the line, then dies, then pick up again... thats where most of my fuel seems to be going.. moving from a stop..
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1192453
you need to find out if the microtech has closed loop control ability
if it does you should check your o2 sensor as it is what the closed loop system runs off
closed loop is where the ecu switches from map to o2 sensor after a stable throddle position has been reached(cruising), then basically tunes to a ~14:1a/f ratio while steady throddle position remains.
hope that makes sence
pete
https://www.sau.com.au/forums/topic/63366-fuel-consumption/#findComment-1194403
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
