hmm this is interesting as i am looking to go down the GT30 route later this year, and was told by alot of ppl to get the 0.63 ex housing, but by the sound of things this is NOT what i want for a street driven car!
INASNT what power are you making with the .86 rear and .70 front combo?
  • Replies 64
Internally stock motor so far
Mel Auto Salon 04 [email protected] bar
Selectamz dyno day [email protected] bar (outside dyno so lots of nice fresh cool air)
Adam - try and get an HKS 2835 Pro S low mount - I reckon they are the best performance / response. Yes you might pay a bit extra for HKS - But they are the Shit and resale is better than hi flow.
wow! my mate seems only able to push ~250rwkw with this turbo on an RB30
what size injectors are you running?
im punching out 270rwkw on 16psi, 16psi @ 4000rpm or there abouts depending on gear etc.
denham, isnt your a .82 rear? i cant remember what mine is.
I thought it was .82. And mine is no different to yours
a .63 would be snappy, mine is so progressive it wont break traction in the dry (except in 1st if your rough)
but still man ..pushing that much on a standard 25 even on a dyno day....how much will it take b4 she splits like a hoe
Denham, what sort of duty cycle does your injectors run at when it makes that much mumbo on the dyno?
Matt
Matt
As a daily driver it runs 1 bar boost and makes around 255rwkw and even with that power driving to work etc I dont drive like a jackass 90% of the time :mad:
As a daily driver driving around at 1.4bar boost is a waste of time, and remember the engine wont be making that much power all the time even if i was running 1.4 bar coz thats just a peak power figure and i aint changing gears at 7500rpm all the time, where that peak power is made.
With the 550cc injectors and 044 pump with stock fuel reg the injectors are at around 80% duty cycle
he dont drive it around like that everyday. His Dyno figures are with octance booster etc in the tanks.
Daily its not making that   :mad:
U still on about that octane booster thing? I just put in a bottle i bough at the local servo before MAS dyno comp because the fuel i had in my tank was over 1 week old
besides.. i really dont think octane will give u that much more .....specially when ur over 300 .....its still over 300 with or without booster. 300 is ****en massive in anyones language for a car thats regularly driven.
and 80% duty is pretty comfortable levels..... good going .. kudos to the tuner thats for sure.
Matt
GT30 with 0.63 a/r exhaust housing come on like a light switch??? YES very much so. You will find it very hard to get off the line in the first few gears with that small housing and you will be in wheel spin city, and then have no power high up in the rev range. And if it raining forget about driving your car.
My GT30 with 0.86 rear and 0.70 front housing (RB25 internally stock) comes on around 1 bar at 4000rpm and makes power all the way to 7500rpm, and bounces off the rev limiter in every gear quite easily, and is easy to drive around normally and come on power nicely without to much wheel spin.
Totally agree with all of the above!
Sacrifice low 4 top end any day..all about power 2 the ground, no use having too much power off the line..ur right, just wheelspin all day long!
Once the GT30 hits full boost around 4500rpm ur already movin' along..so have maximum grip = more power.
INASNT, sounds like u have a very similar set up 2 myself
I have a GT30--high-mounted, external gate, 550cc injectors, 044 pump, GReddy e-manage etc. I am making 256kw (340.5hp) @ wheels (auto) on 16psi.
what rated GT30?
you should be up around 270-280rwkw... if using the 600hp
Yep i know..u mighta missed the bit about it being auto..if it was a manual would more that likely be @ that mark.
Also that 256kw is tuned @ only 16psi.
he enjoys having a cry.
im considering gt30 on a rb20 with no cams or anything, .63, be interesting to see how light switchy its going to be
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
