as the topic says i have my R33 for sale,
it has:
Engine:
full custom 3 inch exhaust
with 7 inch cannon and 5 inch tip
high Flow cat
air filter with cold air intake
jun reprogramed computer
sard fuel pressure reg
bosh 044 fuel pump
gen 2 dual stage boost controler
HKS type s front mount intercooler *600 xx xx*
type 3 megasonic bov
polished engine brace
exterior:
full veilside kit with custom side skirts
carbon fibre bonnet with bonnet pins
new rubbers around front and back windows (due to faded rubber)
modded front bar due to front mount
wheels:
18 x 10 rear wheels with new 265 rubber
18 x 9 front wheels with new 235 rubber
$1500 in receipts for rubber
interior:
pioneer deck with motorised flip face with graphics
boston pro speakers with custom mounted tweeters
2 x response 12inch subs with 2 x 150rms amps with dual boxs
amps flush mounted in floor
2 x A pillar mounted gauges * Boost and air/fuel raito*
Nardi wheel
aftermarket pedals
extras:
aftermarket suspension
upgraded brake pads
upgraded sparkplugs
the reason i am selling the car is because i have a company car and i need for a new toy.
i have a deposit on a new toy so i am selling it.
the car had just under 90,000kms in it when i got it and i have only done around 25000kms since because i do all my ks in my company car.
it also has rego until june.
number plate is*GTSSKY*
i was preparing the car for a bigger turbo but this new toy could not pass me by.
Pricing:
the car owes me around $30,000 including the price of my car.
so i am looknig for around the $20,000 mark, but i am open to offers.
i have pics available but do not know how to post them so send me your email and i will send them out.
in turn i will read up how to do it.
regards
Chris
https://www.sau.com.au/forums/topic/63568-fs-1994-r33-gts-t-veilside/
  • 3 weeks later...
which one was that??
boxing day... so long ago?
the pics are on carsales.com.au under private sellers so could somebody please post a link because i am really REALLY bad with computers
Regards
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
