ok lets just say if this happened hypothetically
ok say a P plater is leaving work and has a lemon lime bitters after his bar shift with is other staff members. If he is forced into driving a car and is pulled over three minutes later after having the drink by a cop and RBTed. what r the chances of him coming out clean.and if he did how??????????????
considering there is a zero tolerance shouldnt the p plater be caught?
https://www.sau.com.au/forums/topic/63600-freak-out/
Think his chances would be SliM :) due to the zero tolerence law. I think the same applies with cough medicine, strepsils and even liquer chocolates!!
However, I think cops have to give him a bit of time for it to digest before doing a RBT - not 100% sure but??
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1195669
Did he really need those 10 drops of bitters? I wouldn't even risk it, just order a lemonade or soda water instead dunno.gif
But yeah, he should have said "I've just had a lemon/lime/bitters 5 minutes ago" and the police will let him wait 15 or 30 minutes before doing the breath test. Hopefully he wont register a reading.
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1196107
Unless he was forced by gunpoint, no-one made your hypothetical person drive except himself.
Dude, he could have caught a cab. Anyway, it doesn't matter WHY he was driving, all that the cops will care about is that he WAS driving, and whether or not he's over 0.00% BAC.
That said, I seriously doubt a lemon lime & bitters will even register on their little breathalyser if he waits his 15/30 minutes they'll allow him.
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1196188
he would be fine. Doesn't lemon lime bitters have no alcohol? thats what i always drink when i go clubbing with the car...???
Angostura Bitters is something like 90 proof (44% alcohol) dude :(
But they only use between 10 or so drops of it, so there's very little alcohol content and it's considered a soft-drink. Usually the alcohol content is negligible, but it might be enough to register a BAC reading in the right situations (thin guy, no dinner, breathtested soon after the drink, etc)
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1196627
That depends. Some laws are enforced regardless of any undue influence: you can't, for instance, kill someone because you were "forced under gunpoint" to do so. This is called "strict liability". Some road related offences are subject to strict liability, but I am not entirely sure which ones are off the top of my head.
As for the situation described by the thread poster, technically (if the Police are doing their job) the driver has committed an offence. Of course, the driver could always request a blood test in the hope that the alcohol clears his/her system by the time the blood is taken ... :D
LW.
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1197025
Hate to burst your bubble of denile Liner Dudes but this actually happened to me (but I aint on my Ps). Got pulled over in my Line by a RBT and was asked the standard question about drinks in the last 15 minutes not realising that lemon lime and bitters had alcohole in it . Blew into the machine and the cop asked what drink I did have cause I was registering ever so slightly on the unit. Luckly well under the limit none the less it still showed up. So be careful out there Dudes and Dudetts !
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1197161
If it showed alcohol reading of over the limit on the breath tester, or any in P plates case, they would have to take you to the nearest police station that has proper breath tester. I forgot what it's called but it's a 15K worth instrument and it's quite large too. Not all police stations have it.
The reason for taking you in is the portable units are not 100% correct and they don't get calibrated that often so it's possible to have false reading. The instrument at the police station has to be calibrated regularly.
After taking your sample the instrument prints out the slip with time/date, location and the reading. If over the limit that is the one that will be used in court and it can’t be beaten except by the blood sample.
https://www.sau.com.au/forums/topic/63600-freak-out/#findComment-1198281
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
