1995 R33 Gts-t (series 1.5)
White
5 speed
110,xxx k's (rebuilt recently with stock internals)
had full service all belts done, water pump replaced etc..
Sunroof
Currently putting out 381rwhp on 14psi and 6800rpm running 10:1afr's on millenium motorsports dyno.... reads lower then dyno dynamics dyno's.
Made 680Nm of torque also :D:
Engine
HKS Gt3037s 56T turbo
HKS ss manifold
HKS 56mm external wastegate
Tomei cams
Tomei cam timing gears
Splitfire coil packs
Greddy plenum
Q45 infinity throttle body
Nismo 740cc injectors
HKS airpod
600x300x100 intercooler
Cusco oil catch can
100mm piping into turbo and i/c
Apexi N1 exhaust
Trust clear cam timing cover
Electronics
Greddy boost guage
Greddy exhaust temp guage
Greddy profec boost controller
Greddy turbo timer
Autometer sport comp monster tacho
HKS F-Con V piggyback computer
Techtom IIC-460 ignition controller
Driveline
Freshly rebuilt gearbox (reciepts for full rebuild and parts)
HKS triple plate clutch converted to twin plate carbon (very streetable)
Locking LSD
17x8 17x9" 5 spoke white rims with near new falken fk451 235&265's
Handling/Braking
Potenza coil-overs
Swaybars
Slotted front rotors
Sport pads front and rear
Body
New front bar probably trust or GTR copy
Side skirts
Trust rear wing
400r Grille
Interior
Recaro drivers seat
Sabelt harnesses
Veilside shift knob
Tinted rear windscreen and rear quarter windows
Sell with RWC and has 4 months rego atm
Easily capable of more power with boost wound up as turbo efficiency range is 1.2-1.5bar from what i've read/heard.
Very quick car.
$22,000, not really interested in trade unless it's for a decent car.... not a shitter and not another skyline.
https://www.sau.com.au/forums/topic/63633-380rwhp-95-series-15-gts-t-22000/
ummm tune is rich but afr's drop pretty smoothly to 10:1 as hits full boost and sit pretty flat..... surprisingly good tune even though richish one. I was down in bris and goldy two weekends ago but don't go down there much :D Went to mercury motorsports thing... woulda put it on the dyno but 50bucks is a lot for a dyno run :)
Pics sent to all
knore -> the piggyback computer uses a maf or map sensor as far as i know in place of the less accurate and more restrictive afm. Not sure what type exactly however.
Jamie
knore-> dont know how the safc2 will go as it has a lot less point on the map to adjust whereas the piggyback i have has quite a lot of adjustment points.
rb20zed-> i tried to email you but i kept getting messages back saying the mail was undeliverable. do you have another email address you can pm me? Yeah as long as i recieved funds before the car left and you paid for the transport i would be ok with sending it to wa.
Jamie
hey mate are there any major scratches or anythin wrong with the car at all cant tell by those pics as they are very blurry if you wouldnt mind taking some better ones of both sides of the car and the full front that would be great. are they bugs on the front of the car?
otherwise looks good
Yeah they are bugs.... haven't washed the car for probably 3 months(i'm not kidding)..... i'll take some pics tomorrow.
Nothing wrong with the car besides the current front bar being "customised" but i'll replace it if sell for the asking price otherwise i can take the cost of new one and paint($600) off the asking price.
is there any stereo or anythin in the car, stains, lifting dash ect lol as i cant see it in reali life its things i would look for :> seeing as i would have to get the car reregistered over here would you be interested in handing in the plates on purchase and taking the money you got back off the car?
no stereo.... no stains no lifting on the trim etc interior is like new except glove box is removed(still have it) and metal plate where stereo and that is so switches and rev limiter are mounted on it. No wear on steering wheel or gear boot and seats. I would deregister car if you wanted but probly wouldn't get much back as in qld think they round it off a lot.
ah fair nuff will you put all the glove box together ect for the sale and is there any interior trim missing. also is the original seat thrown in with the car aswell? also anythin such as the air con missing or anythin like that??? (sorry for the many questions as im over in perth its very hard to inspect a car over there :>)
no sorry i don't know how to put the glove box back in but it will go with the car as will the three near new hks clutch plates i removed to change for the two carbon ones 3 months ago and straight through cat replacement pipe. The original seat doesn't come with the car. I do not have it. Everything is intact still has aircon which works, power steering, abs everything.... it's not a stripped out drag only car more of street drag car.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
