neo32 Posted February 6, 2005 Share Posted February 6, 2005 anyone have any idears i have r32 but comeing out of corners feels real funk like the rear end trails behind any idears people Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/ Share on other sites More sharing options...
MANWHORE Posted February 7, 2005 Share Posted February 7, 2005 perhaps you forgot to put the handbrake down? or the hand brake it adjusted too tight? Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1198012 Share on other sites More sharing options...
nedb Posted February 7, 2005 Share Posted February 7, 2005 Hicas. Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1199751 Share on other sites More sharing options...
itbmils Posted February 8, 2005 Share Posted February 8, 2005 neo32 I also have a R32 GTR - and I had a similar problem( I think) Try a 4 way wheel alignment (I took mine to a WRX guy here in Brisbane) My rear passenger wheel was out by a MILE – even tho I supposedly had a 4 way alignment from one of the 'mainstream' guys only a few month b4 (no names) Also - check that your HICAS is working - I've herd stories about guys pulling the bulb out of the dash so you don't see the warning light come on. HtH Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1199820 Share on other sites More sharing options...
The Dan Posted February 8, 2005 Share Posted February 8, 2005 Check the main diff support frame bushes. tell tale signs are they leak oil when stuffed. also check for irregular tyre wear. also Hicas as mentioned above. Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1200644 Share on other sites More sharing options...
Greg Posted February 9, 2005 Share Posted February 9, 2005 Rear wheel alignment - excessive toe will cause the symptoms your describe. Set it neutral. If you still have hicas, which i will assume you do, you need to ensure the rack is centered before it is aligned. I don't have hicas anymore because its crap, but I was told some Pedders shops have the tools or whatever to center it. Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1201507 Share on other sites More sharing options...
The Dan Posted February 9, 2005 Share Posted February 9, 2005 Rear wheel alignment - excessive toe will cause the symptoms your describe. Set it neutral.If you still have hicas, which i will assume you do, you need to ensure the rack is centered before it is aligned. I don't have hicas anymore because its crap, but I was told some Pedders shops have the tools or whatever to center it. What do you mean tools to centre it. Do you mean the ignition key? Coz when you switch the car off it automatically centres. Wheel alignments are set normally after that. It's only active steer rear ends that need to be locked in place. ie. Hondas Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1202135 Share on other sites More sharing options...
Greg Posted February 13, 2005 Share Posted February 13, 2005 I was just repeating what I was told when I took my car in for a wheel alignment to Widetread Tyres in Lilydale. What you said makes sense Link to comment https://www.sau.com.au/forums/topic/63762-rear-end-feels-funny/#findComment-1206956 Share on other sites More sharing options...
